Help needed the whole thing quit >
Old 07-08-2003 | 12:00 PM
Unhappy Help needed the whole thing quit
A little help please on Saturday the whole thing just quit no power at all. The only thing in the boat that has power is the trim pump. From the gauges, to the inside lights, radio everything has no power. At first I thought it was the battery or a cable to or from it. But after the trim worked that is what is funny or should I say not so funny. We can hot wire the motor will crank over but will not start. The boat is a 1991 Checkmate Convincer 251 GTX if that will help anyone. Thank's for the help
All Trimed Up is offline
Old 07-08-2003 | 12:10 PM
Scott's Avatar
Charter Member #30
My 1st guess would be that the main engine harness is loose. Tighten it up and put a hose clamp around it if it does not have one.
I have Steps & Bubbles!
Scott is offline
Old 07-08-2003 | 12:29 PM
Thanks I will try that but I already thought that might be a problem but I never thought of the camp trick.
Old 07-08-2003 | 04:10 PM
Krumbsnatcher's Avatar
Check to see if your starter ground is corroded if that does not work.
Krumbsnatcher is offline
Old 07-08-2003 | 07:08 PM
All the grounds looks good but I will loosen and clean all of them. Thanks for the help.
Old 07-08-2003 | 07:13 PM
p4-33's Avatar
Try pulling the "umbilical" connector (main power) from your motor and take a look at the pins. I've got an '86 boat and over time, both of the main power pins have broken loose. Merc sells a replacement connector end that splices in pretty easily.
The symptoms I had were identical to what you describe.
Good luck,
Brian
p4-33 is offline
Old 07-10-2003 | 04:32 PM
Get this, after a couple of hours of playing around with this, we found that if you turn on the bilage pump the boat is fine. The control panel must have the ground problem. You turn on the pump and everthing works fine. Have you ever seen that. I have not.
Old 07-10-2003 | 04:56 PM
Vinny P's Avatar
I hate the winter!!
Sounds to me like you have a ground problem. The circuit is most likely finding a ground through the bilge pump.
Vinny P is offline
Old 07-10-2003 | 07:12 PM
FWK
It is definitely a grounding problem.
Old 07-10-2003 | 10:37 PM
Somewhere you fried a wire, you better find it, before others decide to go.
