Finally ready to install
1 Attachment(s)
putting them in tonight.......
Been there...done that:rolleyes:
Good luck;) Have they already been run and leak checked? |
I'm jealous, mine is in my boat, but the dressing and wiring is still unfinished.
Startem up! |
1 Attachment(s)
Originally posted by mopower Been there...done that:rolleyes: Good luck;) Have they already been run and leak checked? thx gonna need alittle luck |
Are they crank mounted water pumps? I just change to those this year myself. I was tired of the hour (minimum) per pump to change the impeller:(
good luck! now drive it like you stole it!
1 Attachment(s)
what a nightmare:eek: :eek:
Got starboard side in, left the trannie on that one will have to take off port trannie off to install..... man no room whatsoever, 33 centers is tight wow.... i had to mill the gils down for clearance........extend the alt bracket it hits the manifolds.....i keep telling myself this is fun:D :D ... i think i'm going to make a trap door under rear seat for easier access to the front of the motors..... i'm gonna need a little help figuring out how to plumb the tee's that sit on the front of the manifolds, i know the up side goes up to the riser , but do i connect the two water ports facing front to each other or block them off???????:confused: :confused: |
Change the Tee's to strait fittings.
WoW , i fired up starboard motor tonight... the thing didn't miss a beat, very chrisp and strong, she is dialed....., i might just make it for next weekend.........
:D :D :D |
| All times are GMT -5. The time now is 03:38 PM. |
