Reverse Lock valve
can i eliminate this??? from what i understand its purpose is to keep the drive from kicking up when transmission is in reverse......
i've been told that a newer style trim pump does NOT require a reverse lockout valve... just trying to confirm what i've been told.... any info on how this works will be greatly appreciated.... thx X
Yes, Oildyne pump does not require reverse lock, just run the 2 hoses from the drive directly to the pump.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Thx Mbam, now i just have to verify that the pump i have is the new style Oildyne...??? It has a plastic reservoir with fill cap in the reservoir...??? I think this is the new one ?????/
Thx again X
Thx again X
Yes, that is an Oildyne. You might need adapters to go from the original #3 inverted flare to the #4 that is used on the later pumps.
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
Pure Energy
07-22-2002 11:56 AM
