HP 500 engine specs
Is there anywhere that I could find the specs for a hp500? I'm looking for things like cam specs, C/R, piston dome (or dish) CC's, valve sizes, head specs, ect.
HP500 EFI -
Camshaft - Crane 169621 - 230/236 duration @ .050, .598/.610 lift, 114° LC
Pistons - JE700 +1 cc (carb should be the same)
Compression Ratio - Static 8.7:1 - Dynamic 6.2:1
Heads - GM14097088 - Open Chamber (118cc), 325cc Intake Runner, 2.19 Intake, 1.88 Exhaust
Idles great only difference I noticed is that it sounds better
I have never stalled it around the docks I have one carb that is starting to get grumpy but it has nothing to do with the cam.
If I am right? One of the weak designs on that motor is the heads there are a lot of better choices. They have the large intakes and the Inconel exhaust valves but they need help with the flow. I had my exhaust side relieved and some mild porting. I also had a tad bit removed to bump up the compression or keep it close after some of the chamber work that was done on the heads. All of this woke it up quite a bit
I have never stalled it around the docks I have one carb that is starting to get grumpy but it has nothing to do with the cam.If I am right? One of the weak designs on that motor is the heads there are a lot of better choices. They have the large intakes and the Inconel exhaust valves but they need help with the flow. I had my exhaust side relieved and some mild porting. I also had a tad bit removed to bump up the compression or keep it close after some of the chamber work that was done on the heads. All of this woke it up quite a bit
I have Steps & Bubbles!
