High rpm cutout? >
High rpm cutout?
High rpm cutout?
Old 07-28-2003 | 12:40 PM
Default High rpm cutout?
I have a pretty muct stock 454/330 in my 1995 velocity 220. It just recently has started to cut out at top rpm (4800). It does not do it all of the time? I have installed new plugs, wires, and a coil, but still did it. Any ideas? I have a new high performance distributor to put in.
MAX VELOCITY is offline
Old 07-28-2003 | 02:05 PM
Rev limiter?????? Don't know if your engine has one or not.
Griff is offline
Old 07-28-2003 | 11:08 PM
mcollinstn's Avatar
fuel pump/fuel filter?
mcollinstn is offline
Old 07-29-2003 | 08:32 AM
mine did it because it had a bad ground connection. might want to check the ground on the batteries and block
Rick
scarabrick is offline
Old 07-29-2003 | 09:17 AM
I don't know if the stock 1995's 454/330 have rev limiters or not?
I will check all of my connections and filters.
Thanks for the input.
The thing that bothers me about this is i can run it hard all day with no problems, then one time out of the blue it will have a slight cut out at top rpm. Then it will be fine again the rest of the day?
Old 07-29-2003 | 08:57 PM
Mr Gadgets's Avatar
Charter Member #601
Sounds like a bad connection, ground possibly..
Good luck
Mr Gadgets is offline
Old 07-29-2003 | 10:13 PM
ragtop409's Avatar
Mine does (1995 330hp) and it comes on at 4800 on my snap on digital timing light. Rag's
ragtop409 is offline
jijo
4
06-11-2008 06:57 AM
HPJunkie
Drives and Lower Units
6
01-27-2008 11:20 AM
Chicago290
6
05-22-2006 03:16 PM
nadledvinka
8
06-29-2005 05:31 PM
kathycool
10
07-01-2003 09:13 PM
