Temp gauge, grounding ????? >
Old 07-29-2003 | 06:24 AM
Default Temp gauge, grounding ?????
Installed sending units in aluminum manifold. Do I need to run additional ground to sending unit. Sending unit is not registering.
Sheikman
sheikman is offline
Old 07-29-2003 | 06:36 AM
Dork
Not registering at gauge?
Some sending units are not compatible with certain gauges. It's possible the replacement isn't. What gauges do you have ?
Old 07-29-2003 | 06:41 AM
VDO Gauges...
Formula 242 stock set up.
Took sending units off 454/365 mag motor.
sheikman is offline
Old 07-29-2003 | 04:49 PM
Did you use teflon tape on the
sender threads ?
If so, you may have lost continuity
to the intake/ ground.
jt.
JaayTeee is offline
Old 07-29-2003 | 06:10 PM
Take a wire with two alligator's clips on it. Now test it by grounding one side to the shell of the case and then to the negative on the battery.
This should tell you if you need it or not.
Good luck.
Brian
Big Boys Toys is offline
masi242
10-23-2008 10:38 AM
mittens
5
09-23-2008 07:42 AM
97BossHammer
8
05-06-2003 08:48 AM
97BossHammer
8
03-25-2003 02:50 PM
