Houston Prop ,Thanks Darin
Got my prop back last week and was impressed
by the 3-4 mph increase in the mid range rpms, much better plane time, and a extra mph in the top speed, the increased lift has improved the ride too thanks again. |
TopDJ
Thanks very much for the Business!!! I viewed the media player download of your boat running hard across the lake ,IT SOUNDED AND LOOKED GREAT!
Thanks again! Darin Murphy |
Those are the exta improvements I am looking for when I send our props in for lab work to Houston.
What boat and prop(s) did you have this work done on. Rick |
rv question on prop
RV > Top DJ sent a Laser Two in for repair and Labbing ,His prop was very thick and the cupping was worn out,as well it was out of balance and pitch,we thinned the blades,added cupping ,Balanced to perfection and Mirror polished the prop to a High Luster Finish!
Darin >281-580-PROP(7767) |
Darin,
As soon as I finish collection the last set of data on the props, I will send them in. What is the lead time looking like now. Rick |
Question for Houston Prop
How often does labbing not result in any gain in top end speed? How often do you have to rework more than once to get desired outcome? I have a 32ft Sunsation with 2-550HP motors and was running 87-90mph (GPS) with stock 32P Bravo I's. I had them labbed, not by you, and am now running 86-88mph. Prop shop agreed to try again but they do not seem to have any confidence there is much they can do to improve.
PROP QUESTION
You need to see if the dia"has been reduced or what,Not sure what was done but will be glad to take a look. Let me know if I can help.
Darin |
Houston PROP !Welcomes
Sean Murphy! , with 15 years exp.in propeller repair ,Sean is helping me in the Labbing Dept. Sean was previously taking care of the bass boaters and pleasure boats .He is now helping me in the Labbing process and we are running two days from arrival.Welcome Sean!!!!!!!!!:D:cool:
TopDJ
Thanks for sending me your avatar! It looks great! /Darin:D
Dadinator
Ddinator if you have time give me a call and we will be glad to answer all of your concerns and questions on labbing your props.Thanks Darin
the numbers after Darin worked this used prop back to shape
OLD could not plane at low speeds New I can plane all tha way down to 28mph Old 3000rpm 30 mph new 3000rpm 34 mph Old 3600rpm 38mph new 3600rpm 41.5mph old 4000rpm 44mph new 4000rpm 48mph old 4600rpm 52mph new 4500rpm 53mph* improved lift and ride. now I just need more horses to turn a little more RPM |
| All times are GMT -5. The time now is 05:16 AM. |
