De-blowered 454 Mag >
De-blowered 454 Mag
De-blowered 454 Mag
Old 08-02-2003 | 11:24 PM
Default De-blowered 454 Mag
I looked at a 454 Mag power twin today that had (a) electric fuel pumps (b) high pressure fuel regulators (c) remote oil filter mounts (d) remote oil drain tubes (e) chrome x-overs (f) red valve covers and (g) four filled-in holes (where screws were removed) on the upper dash, either side of the compass. Boat is showing 130 +/- hrs. I am guessing the boat had blowers on it (and holes were for instrument pods with boost gauges), but broker doesn't know anything. Anyone dealt with a de-blowered 454 Magnum? Should I run in terror? Boat is otherwise in pretty good condition.
SeaWeasel is offline
Old 08-03-2003 | 09:18 AM
Crazyhorse's Avatar
Do a comprehensive engine survey on it and if it comes through alright I wouldn't worry about it.
Crazyhorse is offline
Old 08-03-2003 | 10:24 AM
mcollinstn's Avatar
Compression & leakdown test, and run it hard with the valve cover breathers off and see how bad it blows by.
mcollinstn is offline
Old 08-03-2003 | 02:56 PM
RLW
Mcollinstn,
If it does blow by, can we assume rings?
Russ
RLW is offline
Old 08-03-2003 | 07:52 PM
Crazyhorse's Avatar
That should turn up on the engine survey, which will include (if you hire a good engine tech.) compression check, cylinder leakage test, oil pressure readings with a mechanical gauge, infrared oil and water temps, infrared exhaust assembly temps, and engine rpms at wide open throttle as indicated by a tachometer other than the ones at the helm, either handheld tach or one of the timing lights witha built-in tach. Some engine guys even pipe a barometer into a breather to measure crankcase pressure.
Old 08-03-2003 | 11:51 PM
mcollinstn's Avatar
Blowby is cylinder seal. Sometimes it's just rings. Other times, it is an indication of "more" (as in a worn bore). If the bore is worn, it "may" have been aggravated by washing the oils off the cylinder walls. If so, oil may have been run in a contaiminated state, which can dilute the lubricating properties and smear the first or second layers off the crank and rod bearings.
It's all a vicious circle.
mg503
Baja
14
04-03-2013 04:50 PM
cliff3466
1
03-09-2008 08:10 AM
wet_rat
09-26-2007 12:01 AM
thanks_don
11-19-2006 08:24 PM
Cmoney
3
08-02-2004 11:15 PM
