CMI - bolts keep getting loose >
Old 08-04-2003 | 05:20 PM
maverick1
Question CMI - bolts keep getting loose
I'm runing CMI cool colars on my 502. (Can't say I gained anything but they do look good.)
One problem - the attaching bolts ( header to head) keep backing off - especially #1 and #8.
Any ideas on the "fix"???? I'm getting tired of tightening them up.
MAV
Old 08-04-2003 | 06:49 PM
H2Xmark's Avatar
I would try some blue loctite[#242] on the bolts, you need to clean the bolts and the holes out with cleaner for this stuff to work well
H2Xmark is offline
Old 08-05-2003 | 01:05 AM
I put CMI's this Spring and read about them coming loose for a lot of people. I just checked mine after about every 2 hrs of run time for the first 10 hrs. Tightened them down the first couple times as a lot of them were a little loose. After that, they stayed tight. I think what happens is the CMI gaskets have to burn in and then the bolts get a bit loose. You may need to start with a fresh set of gaskets and bolts.
Some other people said they went to using studs/nuts to bolt up the headers.
Griff is offline
Old 08-05-2003 | 10:09 AM
WALKIN THE DOG
Maverick,
Had the same problem, bought Stage 8 locking header bolts from my local speed shop. Never had to tighten again. Problem solved, they'll cost you $50.00.
Old 08-05-2003 | 08:17 PM
If you use studs in place of the end bolts on each side, life gets lots simpler. Alignment for R&R is easy, the gasket drops in after you have the header in place, and with a crimp type locknut the ends never get loose. Just snug erverything up after the initial gasket "burn-in" and all will be well. --- Jer
jpclear is offline
ghittner
7
05-17-2006 07:54 PM
ratman
9
03-30-2005 06:23 PM
seahawk
9
05-08-2003 03:54 PM
formula31
12
02-18-2003 08:33 AM
RickS
05-01-2002 01:39 PM
