PM 300 - dark and wet plug - help! >
Old 08-10-2003 | 06:56 AM
Default PM 300 - dark and wet plug - help!
Hi!
Number 5 runs dark and wet. The engine stumbles at idle now and then, but runs ok at cruise.
We have cleaned and blueprinted the injector (s), so that should be fine. Swopped the plug with another one, and the dark one went tan, and the tan went dark.
So something is wrong with the number 5. Tomorrow we will do a compression and leakdown test. Maybe its the ignition. Hope so!
I am confused as the engine runs ok at cruise (4.000 - 5.000 rpms), but stumbles at idle.
Any ideas??
Cheeers, Toffen G
Toffen is offline
Old 08-10-2003 | 08:13 PM
homan
can you pull #5 inj. and see if it's a leaker
Old 08-11-2003 | 07:48 AM
sounds like a bad injector to me. had the same problem on one of my 496ho.
Bajaforce is offline
Old 08-11-2003 | 11:20 AM
lewisdre
Is it wet with gas? ANy chance it is water reversion?
u972442
8
07-23-2007 11:22 PM
R Addiction
11-01-2004 07:28 AM
Velocity Tom
09-09-2003 07:20 PM
packinair
01-02-2003 10:27 AM
