TRS outdrive >
TRS outdrive
TRS outdrive
Old 05-21-2019 | 04:45 AM
Full Force's Avatar
Lower gears, especially RH drive.
Full Force is offline
Old 05-21-2019 | 06:40 AM
cigrocket's Avatar
Lower Pinion Gear, RH Rotation. Not enough to support it and keep it aligned. Still a good drive between 500-650HP.. Good deal on TRS Drives and Gear Sets are still able to be found for a reasonable cost. I went the Konrad route. I had about 675HP on TRS drives and I had about 125 hours before issue
cigrocket is offline
Old 05-21-2019 | 08:19 AM
Got a new TRS Left drive line for sale in classifieds..
open87 is offline
Old 05-21-2019 | 08:26 AM
F-2 Speedy's Avatar
Originally Posted by cdowjr
When you over power a TRS drive what usually breaks first?
Cliff in maine
your wallet .....
F-2 Speedy is offline
Old 07-22-2019 | 08:08 PM
Hey Guys,
New here. I picked up an outdrive this week to replace a badly maintained TRS on a 26' Stamas flybridge. In the pics it looked like a TR. Turns out it came off a "military inflatable" and looks just like a TR. No water pick up, 19" prop. Nearly identical to my TR on another boat. If you put them side by side you'd have to look hard to see the difference. It has an extra section between the upper case and where it would bolt to a gimbal and a shifter cable. I removed the top covers to find reverse gears. It was attached to the engine via an automotive type drive clutch. I can't find any record of a TR with reverse. This thing is in pristine condition too. Tried posting pics. Can't do that either I guess.
Looking for some insight as to what this might be and if the parts to attach it to a Merc 350 MPI exist.
thanksobama is offline
Old 07-23-2019 | 05:45 AM
Mbam's Avatar
Offshoreonly Advertiser
Originally Posted by thanksobama
Hey Guys,
That is a 215E from the early 70's. Adapting it to a newer engine is pretty much impossible.
https://www.mercruiserparts.com/215e...5-thru-2915034
Mbam is offline
Old 07-23-2019 | 08:23 PM
Nailed it! Thank you. Much appreciated. Looks like it'd going to Ebay.
Dragon_V
15
04-13-2018 10:23 PM
82LAVEY
22
03-26-2018 03:25 PM
redcorvetteman3
Drives and Lower Units
0
05-21-2007 09:41 AM
gangstav
Classic Offshore
4
04-01-2007 09:43 PM
chuckgo6
7
07-28-2006 12:12 PM
