Some SS hardware help
Charter Member #300
Hi Guys,
I just picked up a use set of trim tabs from Tunnelvision here on OSO. They are from a Fountain - I'm leaving the name on the tabs for my Baja just to piss off you fountain guys!
Anyway, I got a good deal but now face the usual mis-matched and missing hardware predicament. Specifically I need longer pins with bolts on the end and bushings that fit inside the ram connecting rod and have one of those pins going through it. Call is a bushing or a sleeve bearing, I guess. Anybody have a supplier or machine shop that I can get this SS hardware from or have have a similar situation?
Thanx
Thanx
shooter, I work at a machine shop and could see what they would charge to make them. It would be cheaper to but them from the manufacturer if you can. Let me know if you want me to check.
I hate the winter!!
