500hpefi problem >
500hpefi problem
500hpefi problem
Old 08-24-2003 | 11:58 PM
blairjeb
The diagnostic system will not store information like that. You might want to check the wire that runs from your starter to the breaker, make sure it is not rubbing anywhere & grounding out. I'm pretty sure it is a solid red wire, or you could just replace your breaker. the mercury part # is 11178 for the 50 amp breaker. It costs about $50 dollars. Good luck, blairjeb
Old 08-27-2003 | 05:28 PM
maverick1
Red face
I had a similar event. Mine turned out to be my Gel battery would interrmittenly ground internally.
Threw battery away. Problem went away.
Spooln
12
08-15-2007 09:58 AM
Brandon
12
08-14-2007 08:10 PM
Baddogg
10
08-07-2004 09:14 AM
timucin
25
12-05-2003 12:00 AM
