Impeller Change >
Impeller Change
Impeller Change
Old 08-29-2003 | 02:48 PM
jrocket's Avatar
Default Impeller Change
Belive my impeller is going down, water temp rising, oil pressure dropping at idle. I guess what I am looking for is how difficult is the change with motor in the boat and is there anything special I should look for? 502 single in 242 Formula. Any help??? or just dive in??
jrocket is offline
Old 08-29-2003 | 05:31 PM
Von Bongo's Avatar
I found it very easy to do, I can do it in about an hour. Just have some dish soap to help get the impeller in. This assumes that you have good access, which I have always had.
I have no idea what it would have to do with your oil pressure unless you mean that it is getting hot and therefore pressure runs a little low???
Von Bongo is offline
Old 08-29-2003 | 09:36 PM
buck183's Avatar
I have replaced mine several times on my own. Took on the project the first time without any tech advice. I found it to be a VERY easy job. Like Von Bongo, the first time took me about an hour. I can do it in about 30 minutes now. Air tools make a big difference.
It's easy to access on your engine. I have the same one.
Buck
buck183 is offline
Old 08-29-2003 | 09:48 PM
jrocket's Avatar
Thanks I hate going into any thing blind
jrocket is offline
Old 08-29-2003 | 11:06 PM
cuda's Avatar
It should be no problem. I changed them in my 242 with twins, your's will be much easier. Do you have a sea strainer? You might want to check that too.
cuda is offline
Old 08-31-2003 | 07:12 AM
CAP071's Avatar
about 1 hour It's not that hard just make sure you lube the impeller up
CAP071 is offline
Old 09-01-2003 | 06:37 AM
GLH's Avatar
GLH
I did it on my own on both engines it worked and I'm an imbecile.
GLH is offline
rssteiny
2
06-17-2008 02:59 PM
techman
15
04-18-2008 06:02 PM
jaxx 30
Scarab
5
04-10-2008 09:49 PM
RonA
7
05-31-2004 10:50 AM
jrocket
08-29-2003 09:51 PM
