-   -   Tomcat-bypass Valve ? (https://www.offshoreonly.com/forums/general-q/58899-tomcat-bypass-valve.html)
liquid lounge 09-10-2003 10:11 AM
Installing bypass valve[s] this eve. Motor is a Gen6 502. You are only using 1 30psi bypass in the hole closest to the crank and you are leaving the the hole that is centered in the pad W/O a bypass, correct? I am leaving everything else stock. Thanks in advance, Berg:cool:
Turbojack 09-10-2003 10:34 AM
1 Attachment(s)
Goes in hole on side that is round, with the lip. The other one on the side comes from the oil pump.
liquid lounge 09-10-2003 10:53 AM
Wasn't Tomcat advocating omitting the use of the bypass in the hole where the adapter screws on? Thanks for the reply Tjack, but am unable to view attachment.
tomcat 09-10-2003 11:16 AM
Use 30 psi bypass in the round off-center hole. Egg-shaped off-center hole comes from pump. Eliminating the bypass in the center hole eliminates three redundant right turns in the oil supply passage.
liquid lounge 09-10-2003 11:31 AM
Thanks for the replies- I'll do as told:p
