Question about reversion and superchargers >
Old 09-13-2003 | 06:07 AM
Crazyhorse's Avatar
Default Question about reversion and superchargers
Ok, after reading a bit about reversion on pb's thread, you've got me wondering about whether having a supercharger changes the chance of reversion. Does running a blower decrease the chance of reversion? I realize this is probably not an going to be easy to answer, but as I'm a newbie at supercharged engines I need all the help I can get.
Crazyhorse is offline
Old 09-13-2003 | 08:02 AM
Turbojack's Avatar
My guess it NO. This is a problem that only happens at idle or just off idle. If the motor has a blower or NA the motor is in vacuum when at idle. Camshaft design & exhaust type are the only items to worry about.
Turbojack is offline
Old 09-13-2003 | 09:32 AM
Dennis Moore
Indirectly, yes. A correctly cammed supercharged engine will have a camshaft with less overlap so the supercharger doesn't blow the air/fuel mixture straight through the cylinder and out of the exhaust when both valves are open at the same time (valve overlap). Most supercharger camshafts have either a wide LSA or less exhaust duration (some have less exhaust duration than intake duration).
The stock GM marine camshafts used in the 454/502 Mercruiser Magnum engines make fine supercharger camshafts. They have a wide LSA at 115.5 degrees and 224/224 degrees of intake/exhaust duration. Very little valve overlap!
Dennis Moore
www.mooreperformance.org
Old 09-13-2003 | 01:51 PM
Crazyhorse's Avatar
I won't know exactly what cams are in these engines until I disassemble them this fall. The engine builder (the previous owner's engine builder) isn't inclined to give out the cam specs to me, and I can't blame him for that. He did pass a some spring information to me when the previous owner asked him what I should buy to replace them. Isky 8005A, which is a fairly light spring, 130 lbs. on the seat I think, and .600 lift cam max.
I"m going to have one of the engines dyno'd before disassembly to se what kind of numbers it's making.
Old 09-13-2003 | 02:04 PM
Crazyhorse's Avatar
By the way, the engines are 509 cid, J&E flat-top pistons, Merlin rectangle-port heads, custom-ground hydraulic flat-tappet cams, 1050 Holleys on B&M 250 blowers. I had the heads freshened right after we bought the boat this past spring and the engines have performed very well. But gee, we all want just a few more horses, right?
Old 09-14-2003 | 09:46 PM
mcollinstn's Avatar
2 kinds of reversion.
Exhaust reversion (that pulls water into the cylinders)
Intake reversion (that causes air to oscillate back and forth thru the carb, double-fueling it and making it slobbery rich at low engine speeds).
A blower will reduce or eliminate Intake reversion (draw-thru will eliminate it - blow thru will reduce it).
A blower will have no effect on exhaust reversion (versus the same engine with no blower).
mcollinstn is offline
Old 09-15-2003 | 08:04 AM
Doesnt it seem like blowers smooth out the idle a bit? Or is it the mixture that does that? Greg
HPJunkie is offline
Old 09-15-2003 | 08:42 AM
Crazyhorse's Avatar
Yeah, they seem to idle much better. I'm assuming that's because of the reduced intake reversion, probably partly due to the decreased overlap too. I could be wrong though. I'm new to blower motors.
Old 09-15-2003 | 09:21 AM
ursus
Exhaust reversion occurrs when the exhaust valve is not closed before the piston begins the down stroke causeing a vacumn in the cylinder and air/gas to be drawn in through the intake valve and, exhaust/water to be drawn in through the still open exhaust valve. A blower with 5psi of boost will charge the cylinder with 5psi of positive preasure when the intake valve opens and so the piston will have to travel a little further on the down stroke before a vacumn is created until which ttime exhaust/water will not be drawn in through any still open exaust valve. The effect is minimal the same as a few degrees less exhaust overlap, the more boost the more pronounced the effect will be.
Old 09-15-2003 | 09:44 AM
Turbojack's Avatar
"A blower with 5psi of boost will charge the cylinder with 5psi of positive preasure"
This all well & good except when you are at idle. Intake maniford is in vacuum, thus air is not being forced into the cylinders
