540 Bulldog
Old 09-23-2003 | 12:02 PM
leviathan's Avatar
Registered User
Default 540 Bulldog
Any one able to tell me which mark on the crankshaft gear wheel (sprocket) I should use to time the engine.
I have the choice of 3, a circle, a triangle or a rectangle, but I don't know which one to use.
Your help would be much appreciated.
leviathan is offline
Old 09-23-2003 | 12:20 PM
maverick1
Default cam timing
Looking at the motor front to rear, with the crank keyway @ 2 o"clock position ( #1 TDC) the mark @ 12 o'clock is your mark. I believe it is usually the "o".
MAV
Old 09-23-2003 | 12:57 PM
Do you know what the cam should be installed at?I think that degreeing it in would be the best way useing the intake centerline method.Circle was strate up,triangle was advanced and rectangle was retarded from what little I think I rember
FloridianSon is offline
IndianaHeat
Nordic
12
12-16-2004 02:43 PM
bsc
2
08-24-2004 09:53 AM
bsc
16
04-02-2003 08:56 AM
Bad to the bone
01-11-2003 12:27 PM
merlin540
02-01-2002 05:14 PM
