Bogging down engine, need help >
Old 09-25-2003 | 12:52 PM
BajaRunner's Avatar
Default Bogging down engine, need help
Ok my brother has a ski boat (I know, I know).
It has a 351 windser Hi output, He bought it at the beginning of the season, and it needed a bunch of maintenance. It was backfiring, but not anymore.
It has new plugs, wires, cap, rotor, rebuilt carb.
Motor sounds strong, but has a miss while idiling, and when you take off its VERY sluggish out of hole, but top end is fine.
It does have a minor exhaust leak.
Where would you start???
BajaRunner is offline
Old 09-25-2003 | 01:31 PM
formula31's Avatar
Carb, what kind? Is the accelerator pump working and adjusted correctly. Vacuum secondaries or Mech.? Vacuum at idle? Vacuum needle boucing?
formula31 is offline
Old 09-25-2003 | 01:33 PM
220BR
I'd check cylinder cranking compression, manifold vacuum, idle timing and 3000 rpm timing.
Old 09-26-2003 | 07:40 PM
Fuel Filters !!!! especially in a marine application. Also a miss at low RPM can be anything..bad plug gap ..wires..how about what kind of plugs are you running.???
powerqrudy is offline
Old 09-26-2003 | 11:42 PM
1HYPER1's Avatar
What kind of carb
What kind of ignition
What specs are the engine set at
What do the cap & rotor look like
When is the last time the fuel filter was replaced
1HYPER1 is offline
Old 09-27-2003 | 12:25 AM
R Addiction's Avatar
AT Cult Member #3
If you have already replaced normal tune up parts make sure that you haven't crossed any ignition wires first off. If all OK then do a compression test. How many hours?
R Addiction is offline
Old 09-29-2003 | 07:46 AM
BajaRunner's Avatar
holley carb. the plugs wire cap, and rotor are all new and the correct ones. I know he bought them at the dealer. The wires arent crossed and it runs strong at wot, its just taking off.
Old 09-29-2003 | 01:09 PM
AT Cult Member #3
Fix the exhaust leak. Then try again.
BOSS 272
07-27-2007 03:29 PM
Dannyhightower
9
05-04-2007 10:42 AM
Clay Washington
01-16-2006 02:27 PM
JGB
40
02-16-2005 10:26 AM
