Sea Strainer Mounting >
Old 02-06-2004 | 02:07 PM
Nordicflame's Avatar
Cignificant, I'm certainly thinking that the top ports are the "in" (from pickup) and the bottom(s) go to the pump.
The sea strainer collects debris on top of the screen.
Nordicflame is offline
Old 02-06-2004 | 03:39 PM
Cignificant's Avatar
Thx, I'll peak at some in Miami next week to make sure.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 02-06-2004 | 06:43 PM
Kanookstr's Avatar
32' SUNSATION
Yes that's correct
Kanookstr is offline
Old 02-06-2004 | 08:28 PM
marinetrans's Avatar
After in stalling the strainers and take your first ride, monitor the water pressure guage. You sould have 20 to 25 psi when cruising. Any thing over 30 psi. will make head gaskets leak to the outside and may blow off a circulator hose. Then you need merc's water bypass kit.Anything under 15 psi. and you could start making steam pockets in the heads or block. Thats BAD. It can hang up an exhaust valve as it heats up at high speed. Then BOOM!! That means you may need a little longer pickup or if a bravo has side pickups you need to plug the 3 upper holes on each side.
marinetrans is offline
31scarab31
4
03-31-2008 08:46 PM
lakebound03
Drives and Lower Units
7
09-10-2007 01:37 PM
ajs67Donzi
3
11-06-2006 08:52 PM
Shah Mat
1
07-04-2004 07:15 PM
airshares
1
06-11-2004 03:01 PM
