WINTERIZING - the full way! >
Old 12-14-2011 | 11:38 PM
  #111
tcelano's Avatar
Originally Posted by Darreldanger
The hydraulic lifters should bleed down thus relieving the valve springs...Correct???
I don't think the lifters bleed down far enough to completely reseat the valve. I thought the hydraulic piston just takes up the last 0.05 or 0.1??? Someone will correct me if this isn't right.
Also, the valve springs are under a fair amount of compression even when the valve is seated.
I think the best you can do is bar the engine over a half turn or so every month. Let's see, four months of winter = two complete revolutions or one full valve cycle...
tcelano is offline
Old 01-02-2012 | 08:21 AM
  #112
Default Empty Fuel Tank
Originally Posted by Irishtornado
Ditto on this statement with the ethenol in the fuel today I would want it as empty as I could get it to avoid moisture condensating in the tank as well as the octane dropping for those of us that have the boat sit almost 6 months the octane level drops substantially even using Stabil. The rest of it is pretty thorough though although changing the oil twice once in fall and once in spring again seems pretty wasteful due to the fact it's fresh oil.
I talked with Bob Teague about the fuel level issue and He stated that it's better to have your tank or tanks as low as possible and add stabalizer do to the quality of the gasoline that we have Today.I change my impellers in the spring so there not sitting all winter with the rubber vanes bent up in the pump housing.I also turn over my engines by hand about once a month to distribute the valve spring pressures.I put a moisture absorber in my engine compartment.I spray my shift boots,Exhaust bellows with rubber conditioner and then put the drives in the down position. have 500 efi's with 318 hours and have no issues as of yet.Can't wait till Summer..Having my ride custom painted by Mitcher T in Feb
Hank36 is offline
Old 09-20-2012 | 12:15 PM
  #113
Hate to say this guys but its this time of year again for us northerners to start thinking about this. ttt
drpete3 is offline
Old 09-20-2012 | 12:22 PM
  #114
Put one away already. Sad.
Pismo10 is offline
Old 09-20-2012 | 12:32 PM
  #115
Thinking, but not doing!!!YET!
BlueOval is offline
Old 09-20-2012 | 11:13 PM
  #116
It's a sad time of year
2Slow4me is offline
Old 09-20-2012 | 11:55 PM
  #117
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Unhappy
the deep is offline
Old 09-21-2012 | 06:26 AM
  #118
Jolley's Avatar
Still holding off....... A few more weeks..... It is getting colder here at night. We had a really great summer here in Michigan though .............
Jolley is offline
Old 10-01-2013 | 11:09 PM
  #119
CBlakeNS's Avatar
Great write up. Very complete.
CBlakeNS is offline
Old 10-18-2013 | 08:11 AM
  #120
is there a refined/up-dated list with all of the additions/corrections?
CATF800 is offline
