oem service bulletin >
Old 10-02-2003 | 02:08 PM
daven
Default oem service bulletin
All Mercruiser Gasoline EFI and MPI engines produced in Stillwater.
"New Fogging Procedure when laying an engine up for Storage"
In a 6 US Gal remote outboard fuel tank, mix:
5US gal regular gasoline 87 octane
64fl oz mercruiser or Premium plus 2-cycle tc-w3 outboard oil
5 fl oz mercury or quicksilver fuel system treatment and stabilizer, OR 1 fl oz Mercury or quicksilver fuel system treatment and stablilzer Concentrate
Disconnect and plug boats fuel line from water separating fuel filter inlet.
Connect remote outboard fuel tank(with fogging mixture) to the inlet of the water separating fuel filter
IMPORTANT: IF BOAT IS OUT OF WATER , FOLLOW INSTRUCTIONS FOR RUNNING MOTOR ON FLUSH DEVICE
Cool Fuel Models: Start and run engine at 1300RPM for 5 minutes
VST Models: Start and run engine at 1300RPM for 10 minutes
After running time is complete, slowly return throttle to idle rpm and shut engine off.
DO NOT RUN ENGINES FUEL SYSTEM DRY OF THIS FOGGING MIXTURE IN THE 6 US GAL REMOTE OUTBOARD FUEL TANK
Bulletin No. 2001-8b
Note: this change does not apply to carb motors produced in stillwater or Hi- Performance engines produced by mercury racing
Panther
04-25-2007 01:46 PM
Reckless32
3
10-26-2006 09:59 PM
FtLaudGranPrix
02-02-2004 07:35 AM
boot
08-16-2002 11:06 AM
