Priming oil system question >
Old 10-03-2003 | 09:26 AM
Correct Crazyhorse, it's a beeitch to do with my manifolds although it would be easier......I am going to pull the valve covers and see if they (the lifters) are pumped up then I might tighten exhaust back up and set with engine running big blocks don't blow oil everywhere because of the canted valves do they?......if so I will just re-set and try it again....Fred
fred is offline
Old 10-03-2003 | 11:19 AM
Crazyhorse's Avatar
oh yeah, they make a huge mess. call me.
Crazyhorse is offline
Old 10-03-2003 | 11:49 AM
Don't need no stinking mess....what time do you want me to call you?...on your cell or home?....I have both numbers.....I think I will be resetting them cold....Fred
fred is offline
Old 10-03-2003 | 02:45 PM
I do need to make sure the oil is getting to the valve train componets....I'll get that figured out first.....Fred
fred is offline
Old 10-03-2003 | 07:21 PM
Crazyhorse's Avatar
Sorry Fred, we've been playing phone tag today. I'll be around all weekend and I'll have my celphone with me. Call anytime.
Old 10-05-2003 | 04:49 PM
Turbojack's Avatar
I make a carboard box with opening where the adjusting nuts go. I remove valve cover, put this box over & it catches most of the mess
Turbojack is offline
Old 10-05-2003 | 05:53 PM
blue thunder's Avatar
You can buy little clips for the ends of the push rod to control the oil flow with covers off (autozone). Cost very little. The only time I had lifter noise I couldn't easily solve it was the valves hitting the pistons. Hope this is not your problem!
BT
blue thunder is offline
Old 10-06-2003 | 12:43 AM
Fred,
this is what I do when I build my boat motor. With the spark plugs out and the coil grounded I spin the motor with the starter. A couple of spins and I get 20 psi on my guage and oil squirting from my rocker arms. I set all my valves up cold by rotating the motor and adjusting per the manual the ones that line up with the timing marks. You spin the motor again and then adjust the next set. I think it takes 4 spins per the mannual. I then check my valve adjustment with a compression check and i know the engine has oil and compression. I then set the timing marks and drop the distributor and it is always pretty close.
Just how I do it before I fire it up. I am sure someone has a better way.
Good Luck
Don't burn up the starter. give it some time to cool.
FlyFast is offline
Old 10-06-2003 | 05:38 AM
Thanks to all for the suggestions, I am all set now, Thanks again, Fred
fred is offline
Full Force
10
07-27-2008 09:09 AM
Michael1
2
04-15-2007 08:33 PM
Poorsche
2
08-30-2005 12:45 PM
JJONES
5
07-05-2005 02:12 PM
hondatv
5
01-28-2002 05:53 PM
