Hydraulic Steering's in but . . . . >
Old 10-04-2003 | 07:04 PM
Elite Marine's Avatar
Default Hydraulic Steering's in but . . . .
I have just installed a full hydraulic steering system.
I am using the stock pump and stock cap. The cap keeps releasing the air in the system which is good, excep[t it also is dripping fluid all over my freshly cleaned bilge.
What can I do to eliminate this problem? I know that I should also install a reservoir tank and need to plumb this to the cap somehow.
Please advise on how to correct this situation.
Thank you -
Kirk
Elite Marine is offline
Old 10-04-2003 | 07:09 PM
Official OSO boat whore
Yep, I had the same problem with my system. I'd fill the reservoir and then it would puke. I finally gave up and added a remove reservoir and it solved the problem. Just make sure the line pitches upwards to the reservoir. Low points will trap air.
Cord is offline
Old 10-04-2003 | 09:39 PM
RLW
I have a remote reservoir that is plumbed into the stock power steering reservoir. The picture is how I bought the boat. I have since relocated the remote reservoir and rerouted all of the plumbing, shown in the picture, just to clean up the appearance. I still have the "remote" plumbed into the top of the "stock" unit. I fill the "remote" to 30%-40% of it's capacity. I want to leave room for expansion. The black hose, on the side of the "remote", is the return line from the oil/ps cooler. The steel braided line comes off of the bottom of the "remote" and goes to the blue anodized cap/fitting on the stock unit.
I do not know where the previous owner purchased the blue anodized replacement cap/fitting on the stock reservoir that is shown.
Hope this helps.
Russ
RLW is offline
Old 10-04-2003 | 10:27 PM
The cap is shown on IMCO's site. I got mine from CPPerformance.
Cord is offline
Old 10-13-2003 | 08:37 AM
Ratchet's Avatar
Put in a big cooler, "Like a 10-12" engine cooler, and you may not even need the tank.
Quick, easy, clean
Ratchet is offline
fandango
Wanted
1
03-20-2008 07:42 AM
tony davis
01-05-2008 06:49 PM
KN
6
04-21-2007 09:59 AM
Whiteknuckle
49
12-07-2005 07:16 PM
ApachePete
02-05-2003 10:28 AM
