FYI,Houston Prop
Another Question for Houston
I have a 19 Mirage that i banged up pretty good last summer, I hit bottom and bent over all 3 blades. Is this worth repairing or should i spend the 400+ on a new prop. One more question I am running it on a 26 foot Searay with a single 454 330, top speed is about 45 on average. Any tips on getting a little more out of her, should i go for a 4 blade. Any suggetions would be great or a qoute on a repair. I attatched a pic of the prop.
Thank you for you time.
Jason
Jason
Banged up Mirage
Jason,Hey Thanks for asking ,can we repair your prop?
No problem,Thanks for the picture I will put a pic on here and show you what we can make your prop look like after beging repaired by Houston Prop
and If you can call me and we cantalk more in detail about any changes we may need to make ,Thanks again, Darin
FLIP J 5
THANKYOU!!!!!!!!!!!!!!!!!!!
FOR PLACING YOUR ORDER AND WHEN THE PROP COMES IN,
I WILL CALL YOU TO MAKE SURE WE ARE ON THE RIGHT TRACK,
I have everything entered on the computers ,so we should be ok ,Thanks again Darin
Jason
Fulton? yes it came in on 2/06/04 we apoligize for not calling,we are buried in props around here,it's a good thing .
looking at about a week in half,it has been started with several ,Thanks Jason.
if you need it QUICKER for any reason call me at 281-580-7767
Thanks Darin
Thanks Darin
Darin,
Thanks for doing such a great job on the prop! I will post after my test run with it, to let you know how it runs with your mods.
Thanks again for a job well done!
Jason
Jason
