wwwTOPDJcom
Old 11-19-2003 | 12:36 PM
Default wwwTOPDJcom
per: Max RPM for 350 MPI thread that youv'e been posting on.... what prop did you have Houston lab? Mirage 23p?
justinVIP is offline
Old 11-19-2003 | 12:43 PM
found the answer to my ? on another thread; Laser II. What pitch were you running on that big of a boat? My boat is only a 21'2", and I was only running about 57MPH speedo with a 350/260HP. Now I have a 350 MPI Mag and am trying to decide where to start. everyone has said to try my Ballistic 21p to start with, and go from there, which I will probably do. I would love to be able to push a labbed 23p Laser or Mirage though! I guess I'll find out in the spring.... thanks, J.
Old 11-19-2003 | 05:53 PM
wwwTOPDJcom's Avatar
21 laser II worked by Houston top speed is about 54-55 gps at 4700 rpm my motor says 4400-4800 max rpm
boat weight 4000lbs beam 8'3" LOA 25' 4"
stock 1992 mag 270hp shaft listed prop hp of 250hp
mods include thur hull Corsa Q &Quiet, EMI manifolds
K&N air w/snub stack bumped timing
before prop and those mods
I turned a stilleto 21 p to 4400 rpm @ 49 mph
and the Laser II to 4500 49.5 gps
after those little mods and the prop work Im getting
54-55 gps 4700 rpm
like I said my boat really needs a bravo BB combo
because of its weight
wwwTOPDJcom is offline
Old 11-20-2003 | 10:10 AM
thanks again..runs damn good with only250HP on that big of boat! I'd be proud of that!
Old 11-21-2003 | 11:05 AM
I looked at an old post of yours before you did your mods. Looks like the work you did worked out well for you. You must not have had any probs with the Alpha drive like everyone was thinking you might? Thanks again for the info. j.
Old 11-22-2003 | 01:49 AM
HOUSTONPROP's Avatar
Default video clip
Brian,Thanks again for the work,
I, sure liked that little clip of you running across the lake ,you were hauling xss.
HOUSTONPROP is offline
TEAMBAJA
12-23-2004 07:14 PM
FunHome
12-16-2003 07:34 PM
TEAMBAJA
11-18-2003 02:16 PM
packinair
01-05-2003 08:05 PM
