general matainence >
general matainence
general matainence
Old 11-23-2003 | 09:55 AM
David Haag
Default general matainence
I want to go through everything before I put the boat in the water. Shoot me a list of things to service. So far I have oil, gear lube, plugs,fuel filter. I have no manuel so what did I leave out?
Old 11-23-2003 | 11:35 AM
Where do you boat?
Dixie Doug is offline
Old 11-24-2003 | 12:48 AM
David Haag
I have a house on lake mcqueeney in TX. I will use the boat on weekends only.
Old 11-24-2003 | 10:48 AM
BajaRunner's Avatar
make sure your batterys are charged and you put gas in. oh dont forget the plug
BajaRunner is offline
Old 11-24-2003 | 04:35 PM
97BossHammer's Avatar
there was a post about this somewhere, a big long list, I'll try to find it for you, unless someone posts it first.
97BossHammer is offline
Old 11-24-2003 | 11:38 PM
How old is the boat and do you know how well it was maintained or have any service records??? If its more than 3 years old or you don't know the history then:
distributor cap and rotor
pull drive, check alignment, gimbal bearing, and grease U-joints.
exhaust riser gaskets
Griff is offline
Also, check ignition timing.
Griff is offline
automan
Velocity
21
12-09-2004 09:25 AM
26scarab
03-12-2003 05:43 PM
birdog
02-18-2002 08:40 AM
