Blowers Holley vs Wieand
What is the difference? Is one better for marine use?
It looks like the Wieand has a longer nose option that may fit more applications. The Holley has Teflon tipped rotor blades. Holley uses a cross ribbed belt and Wieand uses a 16 rib belt. Wieand is a Holley company so the Holley 250 and the Wieand 256 are priced about the same. For my application (1991 454 mags, carbed, 200 hours, all stock even exhaust) Would the 250/256 be the right choice? Could I get by with the stock Quadrajet and exhaust for a year, then upgrade those next year? Farming was a little lean this year, but ya gotta take care of the toys.;) |
One other thing
Wieand talks about 1/2" pitch blades on the 256 and 8mm pitch on the 456. What does this mean? What does it mean for the engine? |
Mark
Don't forget to take a look at Whipple but I know for sure the carb would have to be changed. Did you get my PM the other day? Roger |
Mark,
It is Gill Exhaust correct ? |
Holley droped their B&M 250 and 420...so that leaves them their Weiand line.
For your setup I like the BlowerShop 250 with a Dominator feeding it. http://www.theblowershop.com/ |
The B&M and Weiand were never known for their efficiency, depending on sizing the Weiand was a bit better typically, but not by much.
No quadrajet, can't do anything with that. Need a 800cfm minimum for your app. Only need Dominator if you want 700+hp which you won't do without a lot of mods to your engine. Dustin |
Roger, watch your mail:)
Scott I've got stock Merc exhaust.:( Mark, I'll look at Blowershop Dustin, Sounds like I can't do it over time. I'll have to save and get the blower, Carb and exhaust all at once. Oh well, one more year of running stock. Thanks guys |
| All times are GMT -5. The time now is 08:16 AM. |
