exhaust block off plate
The stock merc exhaust blockoff plate. Does anybody know what it is made of? Stainless or is it steel? I doubt that it's aluminum.
I had a few that were powder coated aluminum and some others punched carbon steel. The transom assy.
is cast anyway. |
cord
The old ones 1990 series had been made out of alum. the newer ones are steel. i just made a new one out of stainless about a month ago. I still have the old alum. one if you need it. I will just have to find it.
Yes, I would be interested in the aluminum one. How much do you want for it? Can I get it soonly?
262-243-9663 [email protected] |
Re: cord
Originally posted by 454hoho The old ones 1990 series had been made out of alum. the newer ones are steel. i just made a new one out of stainless about a month ago. I still have the old alum. one if you need it. I will just have to find it. |
sorry
I only made one stainless off the stamped steel plate.the other Im sending to cord.
bajalion
I can trace the plate to get you the pattern and might have some stainless steel flat stock. Ill be in touch tomorrow.
baja-I know of a laser guy that could cut them out of stainless. He's not cheap though. It would proably cost you $75 plus the material. Heck, if you did that, I'd even polish them for you. :D
pt # 861776A2 from Merc $38
or from CP performance...........block off plate |
Had a dozen trim pump brackets made. I guess I'll have some of these made as well.
I have a few friends that can do this. They basically say if I make one or 10 it's about the same price. Set up is the PITA. |
| All times are GMT -5. The time now is 07:37 PM. |
