Ring end gap >
Ring end gap
Ring end gap
Old 12-07-2003 | 02:28 AM
Default Ring end gap
How much ring end gap for a 4.47 bore,naturaly asspirated.I run closed cooling so there is less extreme cooling shock.
HARRISONMIRAGE is offline
Old 12-07-2003 | 07:01 AM
KNOT-RIGHT's Avatar
I used the ring manufacturers recomended then add
.002.
Mine are at .008 4.530 bore.
Supercharged 8 lbs boost.
KNOT-RIGHT is offline
Old 12-07-2003 | 08:27 AM
mcollinstn's Avatar
NA closed cooling?
Run std Mercruiser spec for hp500.
caveman, that sounds awful tight for a SC motor.
mcollinstn is offline
Old 12-07-2003 | 08:29 AM
formula31's Avatar
No less than .0045" per inch of bore. And then add .002 for the top ring like caveman said. Err on the big side, too big a gap wont hurt you, too little will.
formula31 is offline
Old 12-07-2003 | 10:50 AM
KNOT-RIGHT's Avatar
Originally posted by mcollinstn
NA closed cooling?
Yes I would say so
Sorry guys I missed the 2
.028
Old 12-07-2003 | 11:12 AM
rmbuilder's Avatar
MarineKinetics
HARRISONMIRAGE,
What piston/ring package are you using?
Bob
rmbuilder is offline
Old 12-07-2003 | 09:59 PM
mcollinstn's Avatar
Cave,
much better.
Old 12-08-2003 | 01:12 AM
It is stock GM.I boaught a zz 502 that I have torn down and are building for marine use.The factory ring end gap was .024 already wich I found interesting seeing as these motors are getting such a bad rap for marine use,for such issues as this.I am glad I tore it down cause the block had a casting pitt in one of the bores and had tobe repkaced.
Smitty
5
05-28-2016 01:23 PM
phughes69
3
10-05-2005 04:21 AM
TTipton
1
12-14-2003 02:31 PM
Crazyhorse
01-12-2002 12:03 PM
