Bravo 1.5 vs 1.36 >
Bravo 1.5 vs 1.36
Bravo 1.5 vs 1.36
Old 12-24-2003 | 07:45 PM
throttleup's Avatar
Havasu cig,
What props were you running with both gear ratio set-ups?
Matt
throttleup is offline
Old 12-24-2003 | 08:45 PM
HOUSTONPROP's Avatar
Default PROPS/GEAR RATIO
I WOULD GO TO THE 1.5 AND LET'S WORK THE PROPS FOR HOLE SHOT,SIMPLE.
AS WELL YOUR MIDRANGE ACCLERATION WILL BE BETTER.
HOUSTONPROP is offline
Old 12-24-2003 | 10:27 PM
An outboard powered boat is totally different when it comes to getting on plane due to lack of toque. With the higher pitch props if they do not break loose the boat will not plane. I tried a set of bravos 4 blades34s in place of my normal 3bl 34 cleavers and I could not plane off unless I trimmed way up to break the props loose. The cleavers come up quick. Thanks Throttle Up for all the help
mmwalters is offline
Old 12-25-2003 | 06:49 AM
throttleup's Avatar
Mike,
Did you get to Key West as planned?
Matt
Old 12-25-2003 | 07:24 AM
Default CLEAVERS
[QUOTE]Originally posted by mmwalters
[B]An outboard powered boat is totally different when it comes to getting on plane due to lack of toque. With the higher pitch props if they do not break loose the boat will not plane. I tried a set of bravos 4 blades34s in place of my normal 3bl 34 cleavers and I could not plane off unless I trimmed way up to break the props loose. The cleavers come up quick.TTT
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
