Crankshafts? >
Crankshafts?
Crankshafts?
Old 01-26-2002 | 11:32 PM
Drew
Post Crankshafts?
Building in my book a mild 496 tall deck blower motor. Looking for a reasonably priced 4.25” stroke internally balanced crank. What are the experienced opinions on Scat or Eagle brand cranks to hold up under 700 to 800 HP. I will be on the low end of this but would like it to be dependable without paying more than I have to for that dependability. I know some will say run don’t walk and go buy a Cola, Callies or (?) but if I can save 5 to 7 hundred why not. There is a lot of good experience along with opinions on the board and I am really looking for any experiences with Scat or Eagle cranks, good or bad. Thanks
Old 01-27-2002 | 10:46 AM
Bruce
Post
If you buy the Eagle or Scat be sure to get the 4340 and plan on machining the journals, and indexing the stroke. The overall cost is still cheaper, the cost difference is just less. Have the assembly balanced yourself, don't buy a balanced piece. My personal opinion for a blower engine you should select a Callies or similar $1,300 crank. You do get what you pay for.
Old 01-27-2002 | 11:24 AM
Post
Those pieces are made in China.
I have talked with engine builders and they have told me of several stories of Eagle cranks snapping in half.
I also suggest Callies, Lunati or Crawler.
DAVE
Dave F is offline
Old 01-27-2002 | 08:20 PM
kook
Talking
ummmmmmm.........aaaaaaa......hem...hem.... he said "SCAT"
Old 01-28-2002 | 08:57 AM
Bruce
Post
SCAT is the starting word in SCATTER! Not a good description for what happened to your engine.
Old 01-28-2002 | 01:11 PM
David's Avatar
Post
I think Mr."kook's" mind is not on boats!
David is offline
Old 01-29-2002 | 12:31 PM
Crazyhorse's Avatar
Post
Aw, get a pair of timed out PT-6 turbines. The exhaust makes a great hairdryer too.
Crazyhorse is offline
Old 01-29-2002 | 02:04 PM
26scarab's Avatar
Post
I run an Eagle , but just like Bruce say's , be prepared to do some machine work to it to make it right.
If you plan on making 800 though I would definitly step up. $1300 for a crank vs. $1500 for a whole rotating assy seems like alot now but when you are looking at the remains of the less expensive rotating assy lying in the bilge you will then wish you would have spent the extra dough.
26scarab is offline
teaguecustommarine
New Products and Member Discounts
7
06-06-2007 05:11 PM
ratman
03-24-2005 07:12 AM
StrikinLightnin
1
12-30-2004 11:15 AM
