back of boat gets black
after every weekend the back of my boat is exaust resadue, what should i do?????. does not burn any oil. took plastic cover off arrestor still gets black[thought would lean out a bit]
FSR is this blue gelatin type stuff they sell at west marine itr works pretty well to remove hot water and exhaust stains
I have a 24 Outlaw that does the same thing. I keep it waxed and it usually cleans right up after use. Not a big problem though, only small ammount of black.
Outlaw - this is pretty common on boats with integral swim platforms than tap exhaust. My 222 Stinger without platform run as clean as can be, but my brand new 28 Sunsation with a integral platform leaves soot. What I use is Simple Green. We always wipe down the boat as soon as were done and simple green loosens it all right up and we towel it off.
- jeff |
Outlaw,
Do you have the external flappers instead of the internal ones? I never had black transom until I changed exhaust tips and went to the external ones. It seems that the external flapper has the water splash against it and strike the transom, this combined with the "station wagon effect" of the swim platfrom causes the water to discolor the transom. I think with the internal flappers the exhaust/water mix will exit out of the transom with a little more force and miss the vertical surfaces. Tim T. |
Carb motor?? Home built?? Could be you're running a little rich. IF it seems to run well and you're not fouling plugs, guess you'll just have to put of with cleaning it.
Mike |
Get used to it I have been fighting that battle for years until an MSD ignition upgrade which burns a little hotter and reduces on the by-product. :)
I have always had black line on the back of my boat too. Since I've been a member of this board, there has been considerable opinions about wasting money on high octane and since the gas prices went to the sky I switched to 87 octane and now I don't get any black at all.
I agree with waterfowl
Merc Service Bulletin 97-9 for Weber states Initial idle mixture screw setting 1.25 to 1.5 turns out. 2to3 turns will cause the engine to run too rich at lower RPMs. I had your problem till I adjusted mine to 1.25 turns (1000' altitude). That reduced the residue by 95%. I use soft scrub for clean up. :D [ 07-02-2001: Message edited by: RickR ] |
You know, I've noticed that as soon as I installed those Halo Drive Showers, the black transom issue went away. Anyone else seen this? I've heard it shoots a ****load of water all over the place.
black stuff
Get used to it, especially if running high hp motors. Greased Lightning works great on it!
If you can run 89 Octane fuel do it, Higher octane fuels tend to add to the soot.
Hey, Outlaw!
What is your motor carb or EFI??? ANd, what speed are you seeing??? I run an outlaw 502 EFI and run high 60's GPS. If you re doing better how are you doing it? MAV |
| All times are GMT -5. The time now is 08:45 PM. |
