compression ratio??? >
Old 01-02-2004 | 04:03 PM
wetterthebetter
Default compression ratio???
hello all
im building a new motor for the boat,its a 350 changeing the pistons for more compression but was told not to go over 9.2 to 1 or the motor will burn itself up,
im usen dart 64 cc heads.
any sugg, on compression and cams,to keep the cost down thinkn of replaceing piston with cast,what do you all think ??? thats whats in it now.
any and all suggestions are needed and welcome,this is also a
merc stern drive
thanks stan
Old 01-03-2004 | 04:20 PM
Crazyhorse's Avatar
Forged pistons are well worth the money and aren't a great deal more than cast. Hypereutectic pistons are available and are a cost effective alternative.
Crazyhorse is offline
Old 01-03-2004 | 05:06 PM
A good rule of thumb for compression ratio and pump gas in marine engines is 9:1 with iron heads, and 10:1 with aluminum. There are things that can be done to allow more compression, but these compression numbers will generally be safe. These are for 93 octane pump gas.
WETTE VETTE is offline
bcarpman
2
09-03-2006 08:59 PM
danielthelen
5
05-09-2005 02:44 PM
seahawk
2
05-24-2004 12:21 PM
daveo1
7
02-04-2004 09:17 PM
HARRISONMIRAGE
1
12-13-2003 07:17 PM
