-   -   Stringer Replacement Formula 302 (https://www.offshoreonly.com/forums/general-q/67819-stringer-replacement-formula-302-a.html)
Audiofn 01-04-2004 12:33 AM
1 Attachment(s)
Then out came the floors. They were bonded to the stringers so I used a very large pry bar to get them to pup up. This is the foam that was under the floors and it reveales the stringers underneith.
Audiofn 01-04-2004 12:34 AM
1 Attachment(s)
Unfortunatly this is what I found. ROT
Audiofn 01-04-2004 12:35 AM
1 Attachment(s)
More ROT :( This is the front of the stringer that goes along the side of the gas tank. As you can see if you look close they did not glass up and over the top of the bunkhead. This allowed the water to travel downt he bunkhead and cause all this trouble. :( Another 30 bucks in material and this would never have happened. Oh well.
Audiofn 01-04-2004 12:41 AM
1 Attachment(s)
I then cut out all the foam that was btwn the two stringers.
Audiofn 01-04-2004 12:42 AM
1 Attachment(s)
Another picture of the stringer damage
Audiofn 01-04-2004 12:45 AM
1 Attachment(s)
I started to then take out the bulkheads going to the cabin. When this boat was built it was made with just plywood that was carpeted NOT glassed in. I am going to change that part of the design.
Audiofn 01-04-2004 12:48 AM
1 Attachment(s)
This is what I was working on tell I found the nightmare :( This is what all the wireing will look like when I am done. Now that the bulkhead is out I will have GREAT access to the dash to wire it up :D
Audiofn 01-04-2004 12:49 AM
1 Attachment(s)
How is this for a NIGHTMARE!!!! Had to take out the Fridge and the Microwave and a bunch of other stuff.
Audiofn 01-04-2004 12:55 AM
1 Attachment(s)
After I got half the bulkhead out I was able to pop out the tank
Audiofn 01-04-2004 12:57 AM
1 Attachment(s)
And out comes the tank.
