How to tell if ALPHA drives are SS variety?? >
Old 01-08-2004, 11:13 PM
NJgr8ful's Avatar
Question How to tell if ALPHA drives are SS variety??
I have an '87 Chaparral Villain 454's and wondering how to know if the alpha drives are SS or not?
NJgr8ful is offline
Old 01-09-2004, 12:00 AM
Alpha 1 SS's lower units
resemble the high perf.
mercury outboard lower unit
( C.L.E. type)
The lower unit has a crescent shaped
leading edge, and a swept back skeg.
Hope this helps
jt
JaayTeee is offline
Old 01-09-2004, 06:51 AM
Sonic30ss's Avatar
They are also 2'' shorter than a std. Alpha
I'll measure mine when I get home tonight and post the results, so you can compare.(wait...that doesn't sound right does it?).....I mean the drive......
Sonic30ss is offline
Old 01-09-2004, 09:54 AM
NJgr8ful's Avatar
Cool Clarity
Thanks jt29OL .. I guess mine are not SS then Sounds like they'd be very easily identifiable. I was thinking (hoping) for maybe a more subtle difference in the looks and maybe more of an inners, gear difference or something. Giving mine a shot at being SS. But mine are 'normal' looking and prolly not. O'well running these with the 454's isn't the primo set up, but for now that's what I got.
Sonic30SS So lemme get this straight. 2" shorter is good for ALPHAs, but maybe no sooo good down ................................ Thanks. If ya get the chance to measure 'it' post your results. Size may matter!
NJgr8ful is offline
Old 01-09-2004, 10:57 AM
cuda's Avatar
The SS is shorter with the CLE, but there are some standard alphas with a CLE nosecone added.
cuda is offline
Old 01-09-2004, 04:23 PM
jaroot's Avatar
measured.. side by side.. my alpha SS is 3 inches shorter Propshaft C/L to input shaft C/L than my Alpha GEN II... 19 inches for the SS, 22 for the GEN II...
The driveshaft housing is unique and irreplacable unless you can find one somewhere... The gearcase is a CLE gearcase just like the outboards.. the Alpha SS gearcase is more beefy than the standard outboard cases in terms of wall thickness, etc but takes the same internal components and the outboard CLE will bolt right up to the driveshaft housing... so no worries if you puke one... i actually have a MODVP gearcase on my SS with the side water pickups vs the low waters that always suck up weeds... i have ZERO cooling issues. I have measured this gearcase combo against a true full SS and it is the same dimension C/L to C/L... just so no one thinks i'm cheating
I also have the alpha SS mounted to my GEN II transom assy... so don't let anyone tell you it can't be done...
jaroot is offline
Old 01-09-2004, 08:58 PM
Infomaniac's Avatar
Finally found a pic of mine.
Had this one behind a blown small block for 8 or 9 years. Pretty old transom assembly.
89 Model Seebold 21 pad V Ran 93 with the 1.32 gears and 27 pitch prop. 5,200 RPM
This pic just before I sold the boat. Smaller prop and mild 350 engine.
Drive still running strong.
Infomaniac is offline
Old 01-09-2004, 11:31 PM
NJgr8ful's Avatar
Cool shhweeeeet
Jaroot very nice & super mint condition! Is that a Donzi she's mounted too? Details, details, details please!!! More photos if you've got em. Thanks for info and pics fellas ... infomaniac 93! w/an ALPHA drive WOW! never would have thunk it possible
Now I'm 100% sure mine are not SS I'll have to keep my eye out for a couple (yeah good luck right?! ) if you say you can indeed mount an SS to a GENII assembly!
Great info folks! Thank you
NJgr8ful is offline
Old 01-09-2004, 11:57 PM
Infomaniac's Avatar
It was a well respected boat around here. The hull was Kevlar. Light as a feather. Would carry the nose like a bass boat. Was the Seebold demo boat. Sat in their warehouse in St. Louis until 1992.
Notice the Recoil speedo pick up. Would trash any pick up sometimes one trip to the lake until I installed that one. The only GPS affordable then was hand held.
Old 01-10-2004, 07:31 AM
Sonic30ss's Avatar
Wow, when I bought my boat I was told how weak the SS drives were, to be careful...Bla Bla Bla....
But it seems there are still quite a few of them still running around.
Jaroot- thats some great info , about the CLE lowers
I'm having both of my drives "gone thru " (bearings, seals&check gears)over the winter, anything I should look for? One, more thing, are your cases powder coated I was thinking of doing that to mine.
THANKS
Quick Reply: How to tell if ALPHA drives are SS variety??
