-   -   water in carb float bowl maybe, how to get it out? (https://www.offshoreonly.com/forums/general-q/68554-water-carb-float-bowl-maybe-how-get-out.html)
Formula Outlaw 01-11-2004 08:51 AM
I think I might have sucked some water up into the carb float bowl. Besides taking it off and dumping it out, is there a quick way to do it, like maybe just disconnecting the fuel line? Would that drain it out? Sticking a papertowl down the butterflys? Any ideas would be appreciated. Thanks..Russ
blue thunder 01-11-2004 09:02 AM
If you had a long syringe type device you could stick the end down the vent tube and suck the water out. You won't get it all this way. Why not just take the carb off?
Dave
cuda 01-11-2004 09:05 AM
After the fuel problems you had, you probably would be ahead to pull the carbs and rebuild them.
Formula Outlaw 01-11-2004 09:19 PM
Cuda, the port engine cleared up just fine. The starboard engine runs fine until I start "jumping around" then it starts dying out. Both engines originally were doing it, but like I said the port one cleared up and runs fine. Guess I'll just yank the carb off. Not like a bike where you can just unscrew the drain caps. I'm going to replace the merc fuel/water seperators with the Racorp units that have a drain bolt to drain water out and a replaceable element. It also filters ALL water where the Merc units don't. I was just thinking maybe there was a quick way to do it I wasn't aware of. Remember, the boat sat from mid Aug. till New year's day without running getting repaired. How did you make out on the hose replacement. Say hi to Deb from both of us. Russ
Big Block Billy 02-06-2004 01:15 PM
Take the carb off turn it over, and dump it out in a bucket. The fuel cannot get past the water in the bowl.
Also use Ispropyl Alcohol in the fuel to absorb water.
Notice how I capitalized ALCOHOL! it's important :cool:
Formula Outlaw's right again ! I had this problem with water. I dumped the filter and carb several times, after there was no more water in the fuel, then I installed a new filter and was on my way. If the water stays in the carb for a period af time it will corrode the diecast parts and make a rebuild necessary. Hope this helps,BBB
Big Block Billy 02-06-2004 01:22 PM
Another thing I did was to take a squeeze bottle and fill it with Isopropyl Alcohol and squirt it in the vent tube and fill the bowls with it mixing the gas water and Alcohol into a burnable fuel. Did this several times after getting rid of most of the water. I've found that the breathers that vent into the flame arrestor actually send crancase condensation into the carb also. Higher oil temp helps allieviate this problem. BBB :)
Reed Jensen 02-06-2004 01:39 PM
Isopropyl alchohol already has water in it... go to a paint store and buy denatured alcohol... it is the pure stuff... works better.
BenPerfected 02-06-2004 01:48 PM
Put a container under the bowl to catch the fuel/water. Remove a lower float bowl screw. Put the screw back and dump the drainage....done.
robyw1 02-06-2004 03:38 PM
Took the words out of my mouth. Although I didn't see what carb you were using. If it is a Holley this will work great. Also for you Holley guys that like to jump around on waves, if you will put jet extension tubes on the secondary jets it should stop this problem.
Roby
Formula Outlaw 02-06-2004 05:23 PM
Thanks guys....As always, help is only the keyboard away...:) :) :) :)
