Sucking the flush hose closed >
Old 01-11-2004 | 07:53 PM
blue thunder's Avatar
You need to remove the water pickup hose from the transom and shove the garden hose down it. Sucking the hose closed will immediately starve your pump for water, very bad thing. Doing it my way will never starve the pump for water, just add some air.
Dave
blue thunder is offline
Old 01-11-2004 | 09:42 PM
Dave
that is what I need to know. Shoving the garden hose down my water fill is much better than sucking the hose closed.
FlyFast is offline
Old 01-12-2004 | 11:33 AM
Glad to help. I believe that is why I never need to replace impellers while most everyone else does.
Dave
Old 01-12-2004 | 05:34 PM
MACDAD260's Avatar
Charter Member #818
The hose gets sucked flat when hooked to my Bravo but, the water stills keeps coming out the exhaust. I don't think that just because the hose is collapsing that it means the water is not getting through. The reason that the engine overheats at anything much above an idle is because, as someone has already said, the water is coming through your house and the hose bib on the house which is a huge restriction. Have you ever seen how small the hole is in one of those. Less than 1/2" unless you have an industrial ball valve which most of us don't. The volume of water getting to the hose is just not there to meet the demand of the Bravo style water pump. I don't see how a stiffer hose is going to help. Maybe I am missing something but, I don't think so. If someone can convince me that a hose that is collapsed by suction will cut off the water flow I am ready to be enlightened.
MACDAD260 is offline
Old 01-12-2004 | 07:36 PM
WILDTHING TAZ's Avatar
B-MAX REPAIR
NEVER WORKED WITH CLOSED COOLING SORRY
WILDTHING TAZ is offline
Old 01-12-2004 | 08:09 PM
formula31's Avatar
Thats why they call them suction hoses. They have the strength to resist being sucked closed. Never tried to suck a milkshake through a straw? Same principal.
formula31 is offline
Old 01-13-2004 | 07:47 PM
MACDAD260's Avatar
Charter Member #818
formula 31,
You have enlightened me. What you say makes sense. Wow! the knowledge you gain from OSO is amazing.
Monty
5
01-13-2004 07:38 AM
liquid asset
03-02-2003 07:23 PM
FlyFast
3
05-13-2002 12:38 PM
Dredgeking
10
05-06-2002 07:29 PM
