Sucking the flush hose closed
My boat likes to suck the flush hose closed. The water comes in from a 1 1/4 thru fiting through the coolers to the bravo raw water pump. From the raw water pump the water flows to the heat exchanger and then out through the risers. I close the trough fitting and then open up a valve to attach the garden hose.
It doesnt take much for the bravo raw water pump to suck the hose dry. With the factory systems is there anything to keep the hose from sucking dry. I have thought about attaching the garden hose without the hose washer so that air will get sucked in before the hose will suck closed. This will cause alot of water to spray but is better than replacing raw water pumps. Maybe if I reposition the water attach point to the transsom this would be the way to go? The water would leak on the transom but who cares?
Does any one else have problems sucking the hose dry?
Do I just need a better hose and more pressure. This will happen at idle power.
Yup you need to get one of the industrial hoses. They are rigid enough that you will not pull the hose shut. Like has also been said if you can get the water flow up you will do better. You need flow not preasure.
Jon
Jon
Put your best foot forward!
How about this? I have a water fill on my transom. It is a 1 1/4 type fitting with a 1/1/4 inch hose that fill my fresh water tank. Why not run a 1 1/4 inch hose to the valve that jpoins my 1 1/4 inch hose into my bravo style raw water pump. Put the hose in and crank it on full and let the water run into my bravo water water pump.
I have closed cooling so i am not concerned about water pressure in the engine. I just want enough water so that my impeller will not burn up and my engine will have some cooling.
Any thoughts?
thanks
Any thoughts?
thanks
How about solid 1 1/4 schd 40 from the water fill to the valve before my raw water pump. the water fill is about three feet above the raw water pump. Put the hose in open the valve and flush.
Is schedule 40 pipe too tacky for a flush system? I know it will not suck close.
I bought some heavy wall 3/4" I.D. tygon tubing that I hook directly to a 3/4" copper city water line (I just remove the spigot and use a full size ball valve). I can run my engine to about 3000 rpm before it starts to suck the hose closed
REMEMBER IF YOU ARE USING A HOSE CONNECTED TO YOUR HOUSE IT IS FED FROM REDUCED LINES RUNNING THREW YOUR HOUSE AND FLOW VOLUME IS REDUCED TO MUCH. YOU WILL ONLY BE ABLE TO IDEAL MOTOR AT BEST. I USE A ACTUAL 3/4 FLOW INDUSTRIAL HOSE & FEED IT WITH CITY WATER FROM A 1" FEEDER. THIS WAY YOU WILL GET THE VOLUME YOU NEED TO RUN ONLY APPROX 2000 RPM. MAINTAINING FLOW VOLUME + WATER PRESSURE IS EVERYTHING!!!!! RON
wildthing,
I have full closed cooling which should give my engine some protection.
Fred,
Maybe I should run a 1 1/4 line from my fresh water tank to the raw water intake manifold. This would give me a ten gallon headstart.
Fred,
