Marine Tek
Old 01-16-2004 | 05:47 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Marine Tek
Will this stuff adhere to a bare flat aluminum drive skeg?
Just replaced my skegs and have a couple of low spots at the welds. Just curious if this stuff adheres to flat surfaces or does it need to be held in by voids? Will it work as a filler for the low spots?
US1 Fountain is offline
Old 01-16-2004 | 06:37 PM
H2Xmark's Avatar
Marine tex will do the job, sand with 80 are 100 grit, then clean with acetone, wipe dry with clean paper towel ,then apply. the grey marine tex works a little better on metals than the white does, check out http://www.marinetex.com/
H2Xmark is offline
Old 01-16-2004 | 06:42 PM
If you're going to paint over it, sand it first. I read somewhere, that when epoxy cures, the surface oxidizes or something, and paint won't stick well. I think I read it in the instructions that came with my Hydromotive nosecone.
Liberator21 is offline
Old 01-16-2004 | 07:50 PM
Vinny P's Avatar
I hate the winter!!
I have used Marine Tex for several things over the years. It always works very well. I highly recommend it as well.
Vinny P is offline
Old 01-16-2004 | 08:31 PM
Who hasn't?
Hey Checkmate, Where do you boat out of?
Old 01-16-2004 | 11:46 PM
Ginger or Mary Ann?
Originally posted by Liberator21
Who hasn't?
Me, that's why I asked.
Old 01-16-2004 | 11:58 PM
ScalpTaker36's Avatar
I used it on my drive sked. Glued on the lower tip. Lasted 2 years than fell off.
That chit is like cement
ScalpTaker36 is offline
Old 01-17-2004 | 06:30 AM
Vinny P's Avatar
I hate the winter!!
Liberator21,
I keep my boat at Al Grovers High and Dry in Freeport. So, I mostly stay on the south shore. How about you, which side are you on?
Vinny P is offline
Old 01-17-2004 | 08:51 AM
blue thunder's Avatar
I had a 2 inch by 2 inch corner missing off the trailing edege of one skeg. Building up slowly I reconstucted the corner from marine tex. It lasted one season so far and after what it went through last year don't expect to see a problem. Love that chit!
Dave
blue thunder is offline
Old 01-17-2004 | 05:25 PM
I boat mostly on the north shore, but I'll drop in at the freeport boat ramp once in a while.
I used Marine Tex to fix a corroded gasket surface on a 74 Vega that kept blowing head gaskets. I drove it a couple of years then sold the car. That stuff's great!
