Closed cooling???
Who's running it? Is it worth the effort if you run your boat in salt and fresh water???
I have it on my 20 footer with a 350. It's definelty worth it in salt water, everything last much longer and you can regulate engine temps better. If an engine has already been in salt, it's not so good.
I'm running it, came on the boat when I purchased. Not sure of the cost, but I like the whole concept. It is amazing marine engines last as well as they do with the constant cold water being dumped into the water jackets. Only problem I've had, and not sure it is caused by the cc, is high oil temps. Engine water temps are good, it has been oil temp problems all along. Hopefully I have that solved now with larger coolers and blocked bypass valves.
Dave |
I have the factory Mercruiser system. I couldn't be happier with it. No problems at all. I would not think of running a boat in the salt without it. BUT, you still have to flush out the raw water side every time you use it to protect everything.
What temp tstats are you running checkmate?
Dave |
just installed a CC on a SBC cost $400. Installed a 180 themostat. I run fresh water only. JIM
Looks like the cost is about $600
BT,
My motor is MPI, I am running a 170* t-stat. The same as it would be if it were raw water cooled. I have never seen the temps get hot even after a good run. |
On motors that are producing more horsepower than they came from the factory, I'd at least run a 160deg. T-stat. I'd also raw water cool the manifolds. I feel that a good seawater pump with a thru-hull fitting is a necessity. Anyway I had experimented with a closed system on a slightly worked 454 mag motor. I ended up cooking the motor because the south bay strainer's holes were too big and the oil cooler got plugged with seaweed. I ended up building another motor without the freshwater cooling system. Also got a better strainer and even installed a Groco basket strainer in the boat. I flush every time with a Perko flushpro. No problems for 2 seasons.I also believe my Jabsco bronze seawater pump is worth the $250 it cost me. Even if you run in freshwater it's still a good idea to flush because of organisms and marine life that can plug up manifolds and wreac havoc! :eek: I would only run a 140deg. t-stat in salt water because the salt can crystalize at higher temps, and accelerate corrosion. :(
BBB:) |
Oh B.T.W.
According to Dennis Moore's books, higher oil temps can be good! Many motors have oil that does not get hot enough to remove condensation, and reach its intended viscosity. Dennis is the man !!! BBB :) |
On motors that are producing more horsepower than they came from the factory, I'd at least run a 160deg. T-stat. I'd also raw water cool the manifolds. I feel that a good seawater pump with a thru-hull fitting is a necessity. Anyway I had experimented with a closed system on a slightly worked 454 mag motor. I ended up cooking the motor because the south bay strainer's holes were too big and the oil cooler got plugged with seaweed. I ended up building another motor without the freshwater cooling system. Also got a better strainer and even installed a Groco basket strainer in the boat. I flush every time with a Perco flushpro. No problems for 2 seasons.I also believe my Jabsco bronze seawater pump is worth the $250 it cost me. Even if you run in freshwater it's still a good idea to flush because of organisms and marine life that can plug up manifolds and wreac havoc! :eek: I would only run a 140deg. t-stat in salt water because the salt can crystalize at higher temps, and accelerate corrosion. :(
BBB:) |
Audio added it to his boat. If you recall, he runs in the salt and would really benifit from it. I don't think he even got a season out of the system before he ripped it off. I can't recall the specific problem though.
Originally posted by Big Block Billy Oh B.T.W. According to Dennis Moore's books, higher oil temps can be good! Many motors have oil that does not get hot enough to remove condensation, and reach its intended viscosity. Dennis is the man !!! BBB :) |
Just rebuilt my 500 EFI's. Ordered the system for $530 each motor. PM or e-mail me if you'd like the contact info. I don't have it on me at the moment to post.
Originally posted by racer-x6 http://i-netmarine.com/ I HAVE USED THESE SYSTEMS ON 3 OF MY BOATS AND NEVER HAD ANY TROUBLE. :D |
BOAT 1 350 ZZ4 MOTOR
BOAT 2 350 STOCK BOAT 3 TWIN 454 BROVO MAG ALL THREE WERE ADDED ON AFTER BEING RUN IN FRESH AND SALT WATER BUT WERE ALLI N GOOD SHAPE (SCALE RUST) THEY ALL RUN ABOUT 170 DEG. |
The most reasonable price I found was from Ocean East Marine for CC. JIM
oceaneastmarine.com |
Originally posted by tmdog The most reasonable price I found was from Ocean East Marine for CC. JIM oceaneastmarine.com |
Your engine internals will stay spotless (even aluminum heads and manifolds).Engine warms up quicker as well.If you are running aluminum manifolds I would leave the raw water to them as they will bring a lot of heat back into the motor.The only thing I don't like about closed cooling is that it clutters up the look of a nice looking engine with hoses and heat exchanger.
Originally posted by HARRISONMIRAGE Your engine internals will stay spotless (even aluminum heads and manifolds).Engine warms up quicker as well.If you are running aluminum manifolds I would leave the raw water to them as they will bring a lot of heat back into the motor.The only thing I don't like about closed cooling is that it clutters up the look of a nice looking engine with hoses and heat exchanger. But, you're right. When mounted on the motors, they do take away from the look. |
Joe I'd love to see pics of your install when its done!!!
Ok. Will do. It should be all buttoned back up by the end of the month.
my new 496 hos look like a black cube with hoses everywhere, must be 345,657,213 hose clamps on these things, but the c.c. is nice, especially during the winter months with antifreeze
| All times are GMT -5. The time now is 08:29 PM. |
