-   -   Alternatives to Corsa Q&Q"s? (https://www.offshoreonly.com/forums/general-q/70856-alternatives-corsa-q-q-s.html)
Reckless32 02-03-2004 06:18 PM
Looking for some cheaper yet effective alternatives to the Corsa Quick & Quiets. My past experience with them was not good meaning they were constantly tripping the breaker.
I'm thinking there might be some cool external mounted "switchables" out there somewhere, or lesser expensive similarly configured split pipe setup using the horse-shoe pipe diversion thru the drive. What would be some good economical alternatives fella's?...Provide websites if you have them handy too...
Otherwise how about anything similar to Corsa's yet cheaper for twins?
MnFastBoat 02-03-2004 06:46 PM
Rick, what I did was go with the Teague 450's
Cost was higher then thier posted prices due to have tehm custom made for the angles on my Cats transom.
I kept the stock silent choice diverters and y pipe in place mostly for not having the resource to pull the motors. But also for sound reduction. While researching mufflers I noticed Corsa and Cmi both using hte cross over pipe setup to help reduce back pressures nad sounds.
With the Teagues even open I am over 13db lower then stock.
Closed you can actually carry on a conversation with no trouble and actually her the stereo under half crank :)
They are not a clamp on, but thru mounted tips.
I know several others on here have them and have not heard one bad thing about them.
Btw, this is on stock Merc 502's
Reckless32 02-03-2004 08:28 PM
Thanks bro. I'll check them out. They can be as loud as they wanna be when open, I just got to have a little conversation ability when the wife is onboard with the girls thru no-wakes and those slow troll summer cocktail cruises at night. Do you know of any others that are similarly configured like those, or are they the only ones? Thru mounted is actually even better as well...
MnFastBoat 02-04-2004 10:11 AM
there are several.
I went with the Teagues because they were electronically controlled with a soleniod, not air operated.
I did not want to have to worry about air pumps and hoses.
Hpi, new product advertising here has something
Gaffrig has the Powertip Silencers, higher price not to mention I do not like the looks of the actuator on the outside of the boat.
Teagues look just like regualr tips, cleaner install also.
IMCO has the Mega mufflers along with a few other models, nice units but the Megas are HUGE in size
they would be good for under the swim deck on some boats as they have clamp on styles also.
There are just so many brands and styles :(
boatfreak 02-04-2004 10:36 AM
I'll second the Teagues. I have a set and love them.
Reckless32 02-04-2004 11:13 AM
What would a set of Teagues run per pair ballpark?
jafo 02-04-2004 11:37 AM
Another vote for the Teagues:cool: :)
MnFastBoat 02-04-2004 05:18 PM
I have seen them advertised from 900 to 995
Includes everything except the switch and wires.
You get the tips, beauty rings, soleniod and instructionis of course.
Mine were a little more due to the custom angles they had to make them.
Here is a link to what they look like on my boat.
http://www.offshoreonly.com/gallery/...sort/1/cat/518
MnFastBoat 02-04-2004 05:25 PM
Here is a copy of text from thier website
www.teaguecustommarine.com
SWITCHABLE EXHAUST MUFFLER SYSTEM
<<< SELECT A PRODUCT CATEGORY >>> BILLET ACCESSORIES VALVE COVERS BILLET FILTER MOUNTS MSD BRAIN BOX BRACKET HI PERFORMANCE ENGINE S.S. EXHAUST TIPS S.S. THERMOSTAT HOUSINGS STAINLESS STEEL FUEL MANIFOLDS SWITCHABLE MUFFLER SYSTEMSfx
ST-450 Switchable Exhaust Muffler System
The best silencing tip on the market today. Meets most OEM and MerCrusier standards. Electronically actuated (no more pneumatic pumps!) allowing a 15 to 20 decibel drop at the top of your fingers. Flow rate is unrestricted in wide open position for most applications. Great for today's loud, high-performance engines, or any straight through transom exhaust when idling or cruising. Parts included in kit: (1) pair 4 1/2" stainless steel exhaust tips, (2) actuator solenoids, (1) relay solenoid, (1) pair 4 1/2" stainless outer transom rings, (1) hardware kit, (1) pair inner flappers, (1) pair outer exhaust lappers, and instructions. May be used on stock 7.4 MerCruiser up to most modified blower motors when running wet exhausts systems. Since all AT-450's are manufactured in house, we'll guarantee all workmanship for one year and electical for 90 days. In stock now! Also available for new HP500EFI.
*Great Time to Install New Exhaust Hose & Clamps
Part Number:
TCM ST450SS 4 1/2" Exhaust System, No Inner Flapper Assembly
TCM ST450SSFP 4 1/2" Exhaust System, With Inner Flapper Assembly
TCM ST450SSHPEFI 4 1/2" Exhaust System EFI
TCM ST450SSHPU EFI Exhaust Tip Upside-down
Reckless32 02-05-2004 12:27 PM
Excellent! Thanks man. I think I'm sold on the Teagues. By the way they look in your pics they are exactly what I'm looking for. The boat will already have the Y-pipe installed so I could do this on the side. I'll of course be looking for a good set of used ones while awaiting delivery to cut the cost even more than the factory installed pricing....Thanks again.
You coming to Miami? If so we'll hook up...
Chris288 02-05-2004 12:45 PM
The ones from Eddie Marine are a bit cheaper,, like 650.. with everything except the switch, which I believe the sun already has..
migpilot 02-05-2004 08:34 PM
Just remember that you will have to drill out your current holes to a tad over 4.5 ". Not the easiest thing to do if you have previouslly drilled 4.0 " Not the hardest either.
Reckless32 02-06-2004 02:42 PM
Hmmm, Eddie marine huh? I'll have to take a look at them. I've got some time before making a decision. Mig i have thought about the 4.5" hole requirement and feel that's the one downside to the Teagues. I know I would be a little nervous trying to cut an extra 0.5" into the standing hole...
PSCHENCK 02-08-2004 08:53 PM
4.5" hole
To increase the holes in the transom from 4" to 4.5" bolt a 4" holesaw inside a 4.5" it will plug up a little but works great.
Chris288 02-09-2004 02:58 PM
I was going to say the same thing,,, just put 2 hole-saw's together.. most have holes in them that you can run bolts through one to the other,, works great..
Reckless32 02-09-2004 07:34 PM
Never thought of that, good info. Doesn't sound so intimidating that way...
