Speed with a 377 6.2 small block?? >
Old 02-03-2004 | 08:24 PM
THEJOKER's Avatar
Default Speed with a 377 6.2 small block??
I'm building a rescue center console boat with an I/O. I'm thinking about putting a single small block in it , boat will weigh around 3900 lbs with motor. What speed should I see. A 500 efi get's ya real close to the 80 mark - BH
THEJOKER is offline
Old 02-04-2004 | 06:59 AM
Offshore Addiction
brian,are you using your hull with a new CC deck!
Old 02-04-2004 | 07:22 AM
throttleup's Avatar
Brian,
With the 6.2 Mercruiser you should see about 68.
With the 6.2 Scorpion you should see about 72.
I used a weight of 2750. 150 lbs less due to the small block vs the big block.
Matt
throttleup is offline
Old 02-04-2004 | 11:10 AM
mikev's Avatar
check out this small block 377 with 385 hp
http://www.powertorque.net/engines.htm
mikev is offline
Old 02-04-2004 | 02:39 PM
THEJOKER's Avatar
Thumbs up
Many thanks for the info gang. Yes that is the plan Al - should be awesome - BH
THEJOKER is offline
Old 02-05-2004 | 06:38 AM
Offshore Addiction
interested in some photos!!! you need to build some darn boats anyway!!
scorpion king
6
06-30-2007 09:18 AM
handfulz28
10-15-2006 02:25 PM
DKerns
5
09-05-2006 01:40 PM
chriscraft240
4
08-28-2003 01:17 PM
Da Patriot
44
11-24-2002 08:27 AM
