These valves OK w/supercharger? >
Old 02-09-2004 | 07:31 PM
GO4BROKE's Avatar
Question These valves OK w/supercharger?
Are these valves good enough to use with superchargers? Exhaust aren't inconnel. But they are a good price and 2 sets are available. Reliability is far more important than saving money. I want these motors bullet proof.
454 CHEVY RACE VALVES 1.88 2.190 - NEW - 16
SquareTrade © AP6.0
BRAND NEW.
GENUINE REV RACE SERIES SWIRL POLISHED 7500 RPM RATED VALVES. 8 EXH. AND 8 INT.
EXH. ARE 1.88" HEAD DIAMETER, 5.23" STOCK LENGTH, 3/8" STEM.
INTAKES ARE 2.190" HEAD DIAMETER. 5.35" LENGTH AND 3/8" STEM. 1-GROOVE
EXH. VALVES ARE 21-2N STAINLESS OFFERING HIGH TEMP. AND HIGH RPM RESISTANCE. TIPS ARE HARDENED. VALVE IS 1-PIECE.
INTAKES ARE SPECIAL HIGH-TEMP RESISTANT 422 MATERIAL. A SPECIAL STAINLESS ALLOY RESISTANT TO VERY HIGH TEMPERATURES.
ALL 16 VALVES ARE POWER FORGED, AND COMBINED WHOLESALE COST OF $175.00.
PART NUMBERS ARE PR5009 AND PR5008.
[img][/img]
GO4BROKE is offline
Old 02-09-2004 | 07:45 PM
Comanche3Six's Avatar
Inconel is all I trust. Bad results would be a expensive.
Comanche3Six is offline
Old 02-09-2004 | 08:12 PM
Reed Jensen's Avatar
Stainless will work if the boost is modest... but the grind has to be right.... or the exhaust will "tulip"... Inconel are the best... What is the brand? Manley? I had Manley stainless exhaust in my engines... they worked well... but I was only running 5 lbs boost.. and rich mixture too. The jack-a** that originally did the valve grind did such a lousy job one of the valves tuliped... after the valves were reground .... no problems.
Reed Jensen is offline
Old 02-10-2004 | 12:01 AM
Your key word in your post is "I want these motors bulletproof"
Go with Manley Severe Duty Intake valves and Manley Extreme Duty Exhaust valves. Extreme Duty are inconnel.
Extreme Duty valves are about $350 per set of 8.
Griff is offline
Old 02-10-2004 | 05:18 AM
GO4BROKE's Avatar
Yeah, thats pretty much what I thought. I just wanted more opinions. Thanks guys! I've been planning on Manley Extreme duty valves. I saw these on ebay, I don't know what brand they are.
[img][/img]
GO4BROKE is offline
Old 02-10-2004 | 10:20 AM
$350.oo for just the exhaust valves sounds expensive... but factor in the labor cost to remove the heads and re-do them after they are burned... makes them cheap!
Old 02-10-2004 | 10:42 AM
WILDTHING TAZ's Avatar
B-MAX REPAIR
IT'S NOT WORTH BEING CHEEP ON A BLOWER MOTOR. YOU SUCK A VALVE YOU WILL THROW BLOCK IN TRASH CAN MOST OF THE TIME. I HAVE DONE IT!!
WILDTHING TAZ is offline
Old 02-10-2004 | 02:19 PM
Griff is correct on this one too.
Due
Dueclaws is offline
Old 02-10-2004 | 04:55 PM
PatriYacht's Avatar
Last time I looked Manley inconel were about 40.00 apiece.
PatriYacht is offline
Old 02-10-2004 | 05:32 PM
Crazyhorse's Avatar
I just bought Ferrea super alloy for $27 apiece
Crazyhorse is offline
