prop help?
Old 02-10-2004 | 09:08 AM
KH0302's Avatar
Default prop help?
Ok, I have a 415hp 454 mag in a 22 Pachanga. It used to have a 1.32:1 AlphaSS drive 22p 4 blade and ran indicated best of 74 at 4800, 10 gal. of gas and me(180lbs.) Now I have a B1 drive 1.50:1 and 21p 3 blade, it runs indicated 70 @ 5000-5050. Do y'all think I should go up to a 22p or 23p, get another mph or 2 out of it?
Thanks in advance!
KH0302 is offline
Old 02-10-2004 | 10:19 AM
Official OSO boat whore
I don't know. Something doesn't seem to be adding up. Either your pitch, the tach, speedo or drive is off. They add up to be 0% slip, which can't be right. Even your old combination comes up with a 3% slip. I'm thinking your tach or speedo is off. Are these gps numbers?
Cord is offline
Old 02-10-2004 | 10:29 AM
throttleup's Avatar
KHO302,
I ran some theoreticals and for top end the 3 Blade is going to be your best bet. You are running at optimal RPM at WOT at the 5000-5050 for the 454 Mag. If you go to the 4 blade your slip will decrease a bit, but by looking at the 22P or 23P you are simply swapping Pitch for RPM but I don't think that you are going to net any increases in speed. You may actually see a decrease by going to a 4Blade.
Julie
throttleup is offline
Old 02-10-2004 | 01:50 PM
KH0302's Avatar
Julie, you nailed it. Thats what I was trying to ask
"by looking at the 22P or 23P you are simply swapping Pitch for RPM" so I believe I'll stick with what I got now.
Cord, no those are dashboard numbers. I guess I'm gonna break down and buy a GPS. Any suggestions?
KH0302 is offline
Old 02-10-2004 | 02:49 PM
I'm using a Garmin handheld and I'm very happy with it. Powerboat just did a short comparisson between some different models. Get an actual speed number and then post back on this thread.
Cord is offline
Old 02-10-2004 | 05:17 PM
KH0302's Avatar
I'm looking at the Garmin products, which do you have Cord? Looks like the lowend is the 76?
KH0302 is offline
Old 02-10-2004 | 08:36 PM
I believe that my unit is now discontinued. I'm using a emap. It's hand held grey scale unit. Very large viewing area which is an important feature. I wanted a hand held unit so that it would be more useful. I take this thing everywhere with me. I'll take it hiking, biking, snowmobiling, boating, I even used it once on a flight back from Florida!
Cord is offline
Old 02-10-2004 | 10:18 PM
rbtnt's Avatar
I had a Garmin 45, 48, 12XL, then a 12CX and this winter I upgraded to a Garmin map76 and love it.
rbtnt is offline
Old 02-10-2004 | 10:29 PM
HOUSTONPROP's Avatar
Default ACCLERATOR PROP DELIVERS
HOLESHOT,MIDRANGE,AND AND USUALLY 3MPH ON TOP END,we can keep your rpm where they need to be on your set-up and pickup 2 or 3 mph,Darin
HOUSTONPROP is offline
Old 02-10-2004 | 10:40 PM
t.rae
Darin got back in town from fl, this weeks been kinda screwy after being gone 2 1/2 weeks. have you came up with the right set up for those trip 300 yamahas.
