420 hydrolic vs. hyd roller teague >
Old 02-14-2004 | 08:31 AM
PatriYacht's Avatar
With a big roller cam (I'm using the Crane 651 cam) you should change the lifters and valve springs regularly, 150 hrs or so. If they break, they make a mess of your engine. The cam specs on the 420 cam are .530/.551 lift, 228/236 duration @ .050. The roller cam has much more lift and while duration is similer, the roller has steeper opening and closing rates. The next larger cam in Cranes inventory, the 741, is what people are using in 502's and 540's. While it will lope more, and propably revert water, it will not perform well. What do you have in that Mustang? It sounds like a mean machine.
PatriYacht is offline
Old 02-14-2004 | 08:50 AM
PatriYacht's Avatar
I don't want to sound like a suck-up to Crane. I've used Ultradyne and Cam Motion but there action is pretty radical and tends to beat up the valvetrain. Crane seems to have the marine market covered pretty well. If you want a wild sounding engine, you need to go with a couple of 8-71's. The combination of belt whine and blower roll gets everyone's attention.
Old 02-16-2004 | 10:58 AM
THE MUSTANG HAS A STRKED WINDSER(395 CU.I.)A 14.75:1 JE PISTONS TRICKFLOW HEADS (330IN,230EX)A 1080 DOMINATOR WITH A PRO FOGGER ON TOP.I DO LIKE THE SOUND OF A BIG BLOWER BUT HOW DEPENDABLE ARE THEY AND WOULD MY DRIVES HANDLE IT?OR WOULD A VORTECH CHARGER MAKE MORE POWER?
j winkelman is offline
Old 02-16-2004 | 11:43 AM
Default BLOWERS
WHO HAS THE BEST DEALS ON THEM? I'VE SEEM AN ARTICLE ABOT A PROCHARGER WITH A COOLER MAKING 730-750 HP FROM A 385MAG MOTOR ON PUMP GAS IF I REMEMBER CORRECTLY.
Old 02-16-2004 | 01:18 PM
Jonas's Avatar
i did all that chit last winter or acutally spring
teageu merlin heads roller this roller that girdles 2 or 3 steps up from the hp 500 cams etc , and got about 1 mph per 2500- spent. OUCH..
cost me almost 10 k when finally done have 502's at as per MR teague 550 -575 hp..
so now want to do blowers seems biggest bang for your buck.
Jonas is offline
Old 02-16-2004 | 01:40 PM
I've been using an Ultradyne 296/305 in my 509 with no problems whatsoever. Idles nice, I get compliments on it's sound and it pulls strong everywhere.
Crane ain't the only game in town.
JohnJan is offline
Old 02-16-2004 | 03:03 PM
Default johnjan
what are the other specs on the cam @.050? Did you have any problem with reversion? Jonas did you start with 502's with hydraulic rollers or 454's with flat tappet hydraulic.and witch merlin heads?(320's?)
Ken N
4
03-09-2008 09:20 AM
jeff32
08-30-2006 07:14 AM
nightmoves
3
05-17-2005 04:57 PM
lukiepal
4
04-03-2005 09:19 PM
paradigm shift
12
08-01-2003 10:30 PM
