Jacobs Marine Master Ignition diagram needed >
Old 02-17-2004 | 09:18 PM
blown formula's Avatar
Question Jacobs Marine Master Ignition diagram needed
I need wiring diagrams &/or installation instructions for a Jacobs Marine Master ignition.
Jacobs sold out to Mr. Gasket and I have spent 3 hrs on hold for them with less than satisfactory results.....
even Summit could not get an answer from Mr. Gasket techs.....
Please help!!
blown formula is offline
Old 02-18-2004 | 07:58 AM
rmbuilder's Avatar
MarineKinetics
I have a set from about 1996. I kept all the paperwork.
Bob
rmbuilder is offline
Old 02-18-2004 | 08:06 AM
rmbuilder's Avatar
MarineKinetics
See if this helps also.
http://www.jacobselectronics.com/pro...rgypaks/ez.htm
Bob
Old 02-18-2004 | 02:25 PM
BAD-HABIT's Avatar
Not sure about their marine products but I bought a system for my 94 Bronco and it was a piece A big waste of money....Went thru 3 coils..Tech support was great and they replaced with no questions or cost but still a waste of money. I didn't notice any gains in milage or power....Really thru off my buddy's snap on scanner....Bought the D.U.I. sytem for my boat and was thrilled with it.....Just my two cents
BH
BAD-HABIT is offline
Old 02-18-2004 | 10:43 PM
Actually added a Jacobs to my first "Blown Formula".... it ended the fouling of spark plugs and added 500 rpm on the top end. I thought it worked great.
Now 3 years later... I need the documents on it.
Help!!
Old 02-18-2004 | 10:51 PM
Jacobs!? Sorry but the best you could is lose the whole unit and start over with MSD.I've tried three times(at customer request)to get their stuff to work,junk!Went with MSD & 6A or 7al box and hauled butt.BOB
Bob280Silencer is offline
Old 02-18-2004 | 10:53 PM
Blown Formula,You must have gotten the ONE that worked!Good luck BOB
Old 02-19-2004 | 04:27 AM
BAD-HABIT's Avatar
Im usually the one who gets the bad one! Glad to hear someone got the good "one"
BH
Old 02-19-2004 | 08:21 AM
rmbuilder's Avatar
MarineKinetics
I have had on since 1996. Same results as blown formula. Works great, plugs read very well, but the biggest improvement came in the mid-range.
Bob
Old 02-19-2004 | 10:29 AM
batty's Avatar
I've had the jacobs system on my boat for about 5 years that i owned the boat. only problem was a coil going bad 2 days before a poker run. figures its just my luck!
batty is offline
