Steering pulling suddenly?
Originally posted by 28Eliminator
CxCx, I had this same problem on my last boat. One of the valves isn't sealing in the steering control valve, so it is trying to turn the boat and you are fighting it. You can get a rebuild kit, but I just replaced it and the problem was gone. I think it was about $100 or so, but that was 5 years ago.
That is how it started and then got worse. Just pulled port side harder when going fast. If the hinge pins need replaced, you should fix that as well, but I have seen boats that had the hinge problem that didn't pull like you are talking about. I know exactly what you are talking about. You have to keep a hold of the wheel tight or it's LEFT TURN CLYDE. Plus the fact that it just started happening all at once.
arrover
4
06-29-2008 09:41 PM
