575 Sc
Old 02-24-2004 | 04:55 PM
jcolby's Avatar
Thumbs up 575 Sc
Is an intercooler standard equipment on the 575 SC merc? If not, is it an option, how much does it cost and what are the advantages? Thanks in advance
jcolby is offline
Old 02-24-2004 | 05:16 PM
later's Avatar
no and no.
later
later is offline
Old 02-24-2004 | 05:19 PM
Havasu Cig's Avatar
Supposed to be about 100 hp increase. When I was at Teague last month he had SuperChillers in stock that are painted Merc blue to match the motor. I would give them a call.
Havasu Cig is offline
Old 02-24-2004 | 05:21 PM
Von Bongo's Avatar
But if it did the advantage would be the ability to run more boost without increasing octaine.
Whipple makes an upgrade kit that increases boost and remaps ECU to still run on pump gas that gets you 75-100hp over stock.
They also have a real slick innercooler to add to the package if you want to do more.
Von Bongo is offline
Old 02-24-2004 | 05:23 PM
38KV's Avatar
ECM have a kit,color matched and bolt on for under $2000.
http://www.extremecustommarine.com/s...=SPRCHRINTRCLR
38KV is offline
Old 02-24-2004 | 07:13 PM
jcolby's Avatar
How much boost does a stock 575 make?
jcolby is offline
Old 02-24-2004 | 07:14 PM
Von Bongo's Avatar
4.5 lbs
Old 02-24-2004 | 07:21 PM
jcolby i can get you a good deal on the same kit that 38kv posted give me a call 917 682 2620 rob
superstar is offline
Old 02-24-2004 | 07:50 PM
jcolby's Avatar
Preciate the help superstar but my question is related to a 28 cat that I am looking to buy that is already equipped with a superchiller on a 575. I am trying to figure out why someone would use the chiller on this particular engine. It does not seem necesary for a motor that is only using 4.5 lbs. of boost. anyone have any ideas what could be done to this set up to make more H.P. and get more use from the chiller
jcolby is offline
Old 02-24-2004 | 08:15 PM
38KV's Avatar
If you have a chiller,you can increase the boost and get more hp.
38KV is offline
