Prop Hub
Old 02-24-2004 | 06:50 PM
racinbird
Default Prop Hub
Whats the best style of prop hub kits to use on a 450ish HP BBC with a bravo 1. I just bought a second prop so now I have one for top speed and one for rough water, I just also want an extra hub kit on hand, but have never looked into it. I don't trust our local marina so im turning to the pros here. Thanks
Old 02-24-2004 | 06:56 PM
38KV's Avatar
Solid hub
merc#835258A1
38KV is offline
Old 02-24-2004 | 07:31 PM
racinbird
Can you get just the hub w/o the kit, I have a key lock and washer on mine so I dont need the entire kit.
Old 02-24-2004 | 10:03 PM
38KV's Avatar
I don't know if you can buy just the hub,but you can get the kit for only $65 including drive sleeve adapter,nut and washer,and it is not a bad idea to have some spare parts.
38KV is offline
Old 02-25-2004 | 06:31 AM
throttleup's Avatar
The solid drive sleeve is part#850821Q11 or 850821A11 (long) or 850821Q12 or 850821A12(short). This number is stamped on the side of the drive sleeve. Retail is $51.25. Sell $41.00.
The entire kit is part #835258A1 or 835258Q1(long) or 835258A2 or 835258Q2 (short). The kit includes the thrust washer, drive sleeve, aft adapter, lock washer and nut. Retail $71.40. Sell $57.12.
Matt
throttleup is offline
Old 02-29-2004 | 09:51 AM
RLW
Matt,
Can a 1" Bravo prop be converted to a 1.25"?
Thanks, Russ
RLW is offline
Old 02-29-2004 | 10:06 AM
RLW, You just need to swap to a XR/XZ hub and your good to go! Steve
509 SC is offline
Old 02-29-2004 | 04:23 PM
throttleup's Avatar
Part number 840389A2 is the large prop shaft hub kit. This can be used on all Bravo 1 props that utilize the Mercury Flo-Torque hub system (square bore hub).
If you have one of the old Bravo 1's that have the splines cut into the center of the prop then you would not be able to convert the prop to the larger prop shaft. The easy way to tell if you have one of these is that the part number on the prop will end in A45.
If in doubt as to what you have post or e mail me a picture of the inside of the prop.
Matt
Magic1
Prop Talk
3
04-03-2008 11:00 AM
35 White Lightning
Fountain
1
09-18-2007 09:30 AM
CN24
Prop Talk
4
08-01-2005 04:59 PM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
