-   -   best header gasket? (https://www.offshoreonly.com/forums/general-q/72586-best-header-gasket.html)
KH0302 02-25-2004 07:17 AM
best header gasket?
I should get the lightnings today, and need gaskets. I've heard this ex Merc Master Mech's stuff is superb. Great reading on his site.
http://www.mooreperformance.org/index.html
deboatmon 02-25-2004 08:29 AM
I used Merc exhaust manifold gaskets on Lightning headers with great success. I also had several studs installed in the heads for the manifolds where possible.
I used double nuts on the studs and socket head cap screws everywhere else. The studs make installation easier in many cases because you don't have to struggle to hold the gasket in place. And, the double nuts really kept things nice and tight. You will need crows foot wrenches to get to most of the nuts on the studs.
I ran everything for a while until all warmed then re-tightened everything. After that I checked a few times, then just check for tightness maybe with oil changes.
Good luck.
BadDog 02-25-2004 09:24 AM
I looked at the Merc gaskets and they did not seem to mate up well to the Lightnings. The gaskets that Lightning supplies worked well.
KCHOTBOAT 02-25-2004 09:58 AM
I use Fel Pro header gaskets. I have used them for several years now and no problems.
RickerTX 02-25-2004 10:18 AM
I also used FelPro gaskets with no problems.
Payton 02-25-2004 11:01 AM
I checked this moring with my local auto parts store. They canget the Graphite impregnated sandwiched gasket that Gil Gil sells for $24, for $13.
38KV 02-25-2004 12:38 PM
I used Fel-Pro #1411 on my previous boat with Lightnings, worked perfekt.
blue thunder 02-25-2004 05:53 PM
Fel Pro 1410 here.
38KV 02-25-2004 09:29 PM
What is the difference between #1410 and #1411?
Tinkerer 02-25-2004 11:00 PM
MR GASKET - the grafite ones.
I have even reused mine a few times.
NO LEAKS
